Help!!! Fuel Gauge Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2010, 06:34 PM
69Bowtie's Avatar
I've got a 69 Camaro and the fuel gauge needle registers about an inch past full. I've disconnected the wiring harness that supplies the sending unit in the trunk but it made no difference. Reading ohms from the tan wire in the trunk it reads about 35 ohms. I've tried a new fuel gauge but it does the same thing. The plug at the gauge reads 11.4 V on the red wire that supplies the gauge & 8.47 V on the tan wire in the trunk that supplies the sending unit when the switch is on. Any help would be greatly appreciated.
Old 08-09-2010, 07:04 PM
LATECH's Avatar
the fuel gauge has a drop resistor in it (on the back of the gauge itself) and it sounds like it is ok as you have the 8 ish volts back to the unit.the gauge will read over the top when there is an open ciruit on the gauge to sender circuit. You have verified the wiring to the tank, so that leaves the tank sender unit or the ground wire. Easier to at least first check the ground wire but also you can ohm the tank unit circuit without removing it ( as a presumptive to pulling the tank unit which is next)the unit will read somewhere between 10 to 95 ( roughly) if it is working and depending on how much fuel is in it. If it is like my 64 poncho the sending unit( It is ) has a ground lead that goes to the frame that is attached to the metal frame of the unit itself as the tank unit flange ring is not a reliable connection and tanks are usually mounted with rubber straps that insulates them ( keeps the straps from rubbing a hole in the tank) Hope this helps
Old 08-09-2010, 07:22 PM
69Bowtie's Avatar
Reading between the tan wire of the sending unit in the trunk & ground I get about 12 M ohms. I have checked the ground wire at the frame and it looks good. Does this sound as if the sending unit is bad to you latech?
Old 08-09-2010, 08:01 PM
LATECH's Avatar
Yea, 12 megohm is way too high. about a million times too high sounds like the tank unit will have to come out.you may find corrosion at the crimp connections at the sending unit lead or ground lead to be the issue.bench test it to be sure you may be able to make a good repair without replacing much of anything. try to keep the gm oem
Old 08-09-2010, 08:07 PM
LATECH's Avatar
Ive seen a lot that of units that the resistance wire needed cleaned and the contact tip that is in bad shape.You can remove the side cover from the sender. Study it and keep the ohmeter turned on ( checking at each contact spot). like I said you can probably fix it . I repaired the one in my poncho. all it needed was the resistance wire cleaned ( carefully) i used a little 400 wet sand very lightly on the contact area and it worked good when i was through.
Old 08-09-2010, 09:15 PM
69Bowtie's Avatar
thanks a buch, you've been a great help. Send me a couple pictures of your poncho if you get time.
Old 08-10-2010, 04:41 PM
LATECH's Avatar
OK I will look around for a pic of my project.I should put it in my avatar actually . Thank you kindly for asking
fuel gauge problems Bracewell Engine 1 10-26-2009 06:19 PM
fuel gauge problems grapro Electrical 5 03-16-2009 02:13 PM
Guages are dead gtipton Electrical 4 05-09-2007 10:14 PM
Fuel level gauge question mattson70 Electrical 1 02-23-2007 06:50 PM
Fuel gauge problems 1969NovaSS Electrical 5 05-05-2006 12:42 AM
