Help with Fuel pump ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2012, 09:49 AM
Its a 1988 chevy 1500 with a 350 engine. I just bought this truck ,and it was running but had to get the fuel tank cleaned and replaced fuel pump and sending unit cause it was all gunked up from old gas. just put it all together and now it want run. meaning fuel pump. and plus there is no fire at fuse under hood on firewall. I checked fire at plugin were it connects to sending unit,and with the plug unpluged, it has fire on middle wire but when i plug it up it loses fire, meaning i took a test light and tested both middle wires on each side of the plug ends ,but i can unhook it and the middle has fire.can someone tell me how the fuse might have lost its fire and and were should i start. Im not that good with this kind of problem but with some good advice i know i can fix it. thanks
Old 06-12-2012, 10:39 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Hmmmmmm. I'm kinda confused. What middle wires are you talking about? Can you post some pictures?
Old 06-12-2012, 11:06 AM
Im talking about were it plugs together at the fuel tank. or from truck wire harnest to fuel pump at fuel tank. the plug has 3 wires , 3 going from plug to fuse box , other side of plug goes to fuel pump in tank.
Old 06-12-2012, 02:11 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The wiring schematic on www.autozone.com indicates that the ECM energizes the fuel pump relay. This will run the pump for a few seconds to pressurize the system.
Once the engine starts and builds oil pressure a separate oil pressure switch closes and powers the fuel pump.
There is also a fuel pump prime connection (test) point under the hood. This test point is for priming and testing only
To test the fuel pump, run a jumper from the battery + to this test point.
Also, connect a fuel pressure gauge to the fuel pressure test port.
The TAN/WHITE wire is the fuel pump wire. You must have 12 volt+ on this wire for the fuel pump to run. Also, the fuel tank must be solidly grounded for the fuel pump the work.
vicrod
Old 06-12-2012, 02:33 PM
vicrod
thankyou for your advice , after reading your post ,i went and checked the ground at the tank,and put a test light clamp on the ground bolt and touched a pos wire ,and light didnt lite up, so i took bolt off and cleaned it and frame good and hooked it back up and turned the key on and i heard the pump for about 2-3 sec then cranked it up
Old 06-12-2012, 03:38 PM
EOD Guy's Avatar
Good to hear you got it fixed
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Inline fuel pump vs. in tank fuel pump wheel-7 Engine 2 09-02-2006 06:57 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-04-2006 11:56 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
