Help Garage door opener kicking my butt! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2009, 09:46 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Question Help Garage door opener kicking my butt!
Hey Y'all.
I replaced wires on my cousin's garage door opener to install insulation & sheet rock . the staples made it impossible to remove the wires had to go thru beams.
Now it will not light up the lights on the sensor & will not go down.
I have checked all the wires with a OHM meter & as far as I know all the wires go to the right spots .{I did them one @ a time so this would not happenso I thought}
It a Craftsman chain drive.
Please can someone show me a wireing diagram Or what I am doing wrong?
Thanks
"SlowRide66"
"Illegitimis non carborundum"
Old 09-28-2009, 10:59 AM
302 Z28's Avatar
Does it show any sign of getting power at all?
Vince
Old 09-28-2009, 11:50 AM
Rob Keller's Avatar
Wiki Edits: 38
I have NO power to the sensors on the door all the wires are connected & the key pad & inside button want to work.
I must have broken something.
R
"SlowRide66"
Old 10-04-2009, 06:18 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Did the wires to the sensors get stretched? If so, you may have broken on of them. I would get a couple of short pieces of speaker wire, pull off the sensors, then reconnect them to test. You can do this by laying them on top of the ladder whaile testing. If they work, then the wire from the opener to the sensor is broke and will need replaced. Just by taking down the opener shouldn't have broken anything unless it was dropped.
Old 10-04-2009, 08:22 AM
Rob Keller's Avatar
Wiki Edits: 38
I got it fixed .
I called a Friend of mine & he took readings from his opener with a OHM meter.
So when I went to check this one I had a bit of trouble getting the connector off.
While wiggling it the light flickered.
So I put it back on & wiggled it & it came back to life.
Even My Cousins Friend ,a electrician could not finger that one out.
Oh well , Live & learn , Right?
Thanks for all the help everyone!
R
"SlowRide66"
Safest garage heating method rayn Garage - Tools 6 08-30-2009 12:33 PM
Garage Workshop ckucia Garage - Tools 11 11-20-2008 06:42 AM
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 09:18 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
