help with gear ratio selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2011, 09:22 PM
377tk's Avatar
I am running a 80 malibu it currently has:
flat top 350 9.5 to 1
294s magnum cam
strikeforce 210cc runner 64cc heads
victor jr intake and 650 double pumper
350 turbo with a 3000 stall.
I am in the process of assembling a ford 9 inch for it and am looking for gearing suggestions for a good street/strip car . I am considering 3.89 gearing but what will work well with the 294s cam and my set up. I currently have 3.42 gears and it runs mid 12's, but I am looking for more. I am shifting a 6k. I am running 29x10x15's in the rear. Any help would be appreciated
Old 10-19-2011, 01:44 AM
ericnova72's Avatar
More for Less Racer
With the big 29" diameter rear tire, I don't think you'll see as much change as you would like from just going to a 3.89 gear from the 3.42 you have now, likely only a tenth or two in the 1/4. I'd go 4.11 at least, and really 4.30 or 4.56 unless you really don't want to give up too much rpm for street driving. 4.30 would be my choice.
Old 10-19-2011, 03:31 AM
Bonneville462's Avatar
I would use 3.08s with a 2.75 first gear in the Turbo 350...
Gear Selection Question j absher Transmission - Rearend 9 07-28-2011 09:20 AM
Comp Ratio and Cam Selection 70bird Engine 10 09-28-2007 12:20 PM
gear ratio selection 383silverado Engine 0 09-14-2007 12:29 AM
C4 Speedo gear selection RAW Transmission - Rearend 2 01-04-2007 10:26 AM
gear ratio selection oldblue4x4 Transmission - Rearend 5 09-10-2003 07:50 PM
