HELP!!! Going to upgrade need some head and cam advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2004, 03:33 PM
New Member
Last journal entry: cut, grind, and weld and then repeat...
this is the parts list on my existing
engine combo, i am going to step it up a
bit due to better financial situation ....
A sbc 355 high tin orange block, speed
pro hyperetic pistons,steel crank, gm
pink rods, 9.5 compression, comp cams
xe268 kit(springs retainers dbl roller
chain pushrods...the works), 1.5
rockers, stock fuel & stock oiling, vortec
64cc heads modified to
accept the .48 lift, 1 5/8 headers long
tubes, edelbrock air-gap
vortec intake, holley 600 carb this is in a
77 nova 3300 2.73
gears stock converter... but now i have
finally graduated
college i am looking at a 68 thru 72
nova same engine same t350
but 3.73 gears, posi trak, 2200+
converter, i am wanting to get a
little more out of the engine so a cam
head swap is due
i like the comp cam xe 284 and AFR
heads but unsure about the
CFM and how high to spin the mouse up
to.... any suggestions
will be greatly appreciated
LeeMoses
Old 07-19-2004, 06:40 PM
Not a bad plan. I'd want a 3000-3200 stall speed with that cam. I'd go with even more unless you;re going to do a lot of highway driving. Something like 4.56-5.13 depending on tire size. Go with a 650-750 double pumper carb.
