Help with guesstimate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2006, 06:51 PM
BMM BMM is offline
Hello. I recently bought a used 350, which I plan on rebuilding and putting some performance parts in it. However, I have never done this before, so I have no clue whether there are a bunch of small things for every large thing. So I was hoping you guys could help me figure out what Ill need for what I plan to do?
Putting on new intake manifold (Manifold, Gasket, bolts?)
New bearings (pretty basic)
Needs oilpan (and oilpan gasket)
Piston rings?
Cam and Lifters (I have NO clue if that means I need any new bits and pieces, or new springs, keeping in mind the cam will be pretty mild)
Headers (and gaskets)
So, assuming nothing major (cylinder walls, pistons, rods) have gone, could you guyds help me figure out what Ill need to do this?
For example, i am unsure if putting in a new cam and lifters is just installing them, or if there is other things that will need to be added, just like manifolds need gaskets.
Thanks for any help...I am pretty lost.
Old 10-14-2006, 07:21 PM
steve t's Avatar
ex biker, now hotrodder
your best bet is get a engine manual and read it over twice, people here can also help you
Old 10-14-2006, 07:54 PM
kringold's Avatar
ATA Welding Technology
Last wiki edit: How to rebuild an engine Last photo:
You'll need some assembly lube.
Guesstimate Pr0blumz Engine 6 05-12-2006 03:56 PM
blue smoke panhead65 Engine 11 01-04-2004 03:26 PM
