HELP !!! harmonic balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2007, 08:02 PM
just put on a new harmonic balancer in a 350 chevy '68-85 crate motor.. damper bottomed out. put pully back on and now crank pulley and water pump pulley no not line up.. the crank pulley is "inward" by 1/4"... the new balancer is made by pioneer, #da-3502.. the total depth of the balancer is 2 5/16"... my water pump is a short pump that measures 5 7/8 inches... CAN ANYONE PLEASE TELL ME WHATS WRONG.. THANKS
Old 05-07-2007, 08:16 PM
DeathRattle's Avatar
Some Punk Kid
Sounds like its just thinner.
I had the opposite problem with the damper I bought. I had to shim out all my accessories 1/2". I used 3/8" ID aluminum and steel tubing and washers where applicable. I recently switched to square tubing for more support.
I would wait for some other idea's from the more senior members that would have some more experience. I just wanted to tell you what I did. I don't know how well crank pulley shimming would work and how safe it would be for the long term.
Old 05-07-2007, 08:37 PM
Decho's Avatar
Without risk, failure happens
Last journal entry: Almost finished
Dampner alignment
Are you using the original pulleys? If they are new, are they a set, i.e., did you buy them from the same manufacturer?
If you use a short water pump, you need short pulleys, you can not interchange them.
Also, the cheap, Taiwan-type made pulleys do not always line up.
If you have a speed shop nearby, a good parts guys can get you the correct pulleys, pump, dampner to match.
Dampners typically are consistently the same depth, but some time you have to try a number of combinations to get everything to lineup, however, you should NOT have to use shims behind a pulley, and frankly, I wouldn't recommend it.
Hey, if hot roddin was easy, the big three would be building them!
Old 05-07-2007, 09:22 PM
DoubleVision's Avatar
As said, the set has to match, if you have the damper you removed measure it`s distance compared to the one you have now, that`ll tell you if it`s the damper or if the pulley`s don`t match.
283 Harmonic Balancer JamesD Engine 29 03-14-2007 06:36 PM
Harmonic balancer question tornado-tech Engine 12 02-07-2006 09:00 PM
Harmonic Balancer Installation DTL504 Engine 2 06-15-2004 11:17 AM
harmonic balancer install gkev Engine 1 09-08-2003 07:51 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 05:10 PM
