Help with Head / Valve Spring selection - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-21-2011, 02:26 PM
SSedan64's Avatar
Originally Posted by F-BIRD'88
What does it say on the cam card for installed/seat and open spring pressure?
Calls for 26981 Beehive.
Install Ht.= 110Lbs. @1.700", Open= 292Lbs @1.175", Rate= 347Lbs.
or 26918 Beehive springs.
Install Ht.= 125Lbs. @1.800", Open= 367Lbs. @1.150", Rate= 372Lbs.
Flat head Valve spring remover Tool??? pk44 Garage - Tools 4 08-20-2009 09:08 PM
HEI Spring Selection Custom10 Engine 3 05-16-2009 10:39 PM
Valve Spring Replacement, While Head Are On Grouper Engine 2 05-16-2008 07:57 AM
Comp Cams Valve Spring Questions - Selection leejoy Engine 5 11-08-2007 11:28 AM
spring selection bighotroddin Suspension - Brakes - Steering 2 09-03-2003 09:02 AM
