Help with Head / Valve Spring selection
I need help too pick put the right valves ,springs ,and pushrods for my setup. I am using an older gm block, 3970010 bored .030 ,have a retrofit comp cam part#12-600-8 VALVE LIFT @ 1.5:1 .511"in .497"ex ,retroroller lifters. The heads i want too use are the 305 416 castings, only because they have been ported allready but that is all that was done. Pistons are silvolite .030 with 4 valve relief. If anyone can help with part numbers i need that would be great, alos i am looking at roller tip 1.6 rockers from comp cams. So figure them as well...Thanks in Advance..
call comp about the springs when you get the valves figured out
800-999-0853 |
CompCams shows what to buy too match the cam ,but they do not tell you the head that it is to be installed on, and the prices are overkill, i see a great selection on ebay from big names, but need part numbers and specs..
Most people i emailed at speed shops, tell me to go with a .200 longer pushrod for roller cam, some said .100..some list thier springs to handle up to .550 lift..but only recommend them for flat tappets and not roller..so i am very confused..
i believe you need to get your heads built and then measure for pushrods
but im sure someone else here knows more than me about it |
Cole |
ok so if i take my caliper and measure around the outside of the spring that will give me the thickness, and then i measure the seat on the head across to find the width of that , but for spring height..dont i need the proper valves first..as i am changing them as well?
If you have no valves then yes you need them to get the height. When they ported did they also change the size of the seats or did they leave the stock size? If still stock do you have the old valves?
For most applications on stock SBC heads there's only two different lengths. Stock or +.100 for your application the stock length would be fine. If they left the seats stock and you still have the stock valves then you can use them to get the approximate installed spring height. At least close enough to know which springs to order.
BSE Racing Engines |
the heads were left stock, and all parts are still installed, the guy who owned them before me , just had them rebuilt and ported, and put about 5000km on them and then took them off when he got rid of his car due to an accident. I was thinking of leaving the stock 1.5" exhaust valves and just putting in new 1.94" intake valves..will that work or do i need to replace the exhaust valves with performance ones...thanks
Tough call. While the heads have only 5000km since the rebuild the valves themselves have ???? miles? You can get 1 piece stainless valves from places like Competition products for fairly short money. In this case $6 a piece.
http://www.competitionproducts.com/S...uctinfo/E2809/
Since you're planning to upgrade the Intakes and you need Springs etc..
It will be cheaper to get a matched kit. Examples: 16= 8-1.94" Intake / 8-1.50" Exhaust http://www.competitionproducts.com/S...ductinfo/8430/ Valves/Springs/Retainers/Locks/Seals http://www.competitionproducts.com/H...ctinfo/851395/ Last edited by SSedan64; 01-21-2011 at 08:54 AM. Reason: spelling |
| Flat head Valve spring remover Tool??? | pk44 | Garage - Tools | 4 | 08-20-2009 09:08 PM |
| HEI Spring Selection | Custom10 | Engine | 3 | 05-16-2009 10:39 PM |
| Valve Spring Replacement, While Head Are On | Grouper | Engine | 2 | 05-16-2008 07:57 AM |
| Comp Cams Valve Spring Questions - Selection | leejoy | Engine | 11 | 11-10-2007 05:42 AM |
| spring selection | bighotroddin | Suspension - Brakes - Steering | 2 | 09-03-2003 09:02 AM |
