help with headers and burning wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2005, 03:17 PM
i have a 79 camaro with a 350 in it. i just purchased this from a kid who didnt know sqwat about cars. he had a short water pump with nuts and washers for spacers to bring it out to the long shaft placement and the power steering pump bracket was held on with one bolt because the others did not line up. The alternator im not sure how he got it working. I have since replaced all the items on the front and gotten it to run nice. my problem is the headers i have seems to burn my spark wire boots. it looks like there to close to the boots with normal plugs. ive gotten a set of shorty plugs from accell but not sure if there any good. also the number 5 and 6 plug i cant get my socket onto because of the header pipe is right over it. Whould shorty block huggers work better or? im about to put a new carb and go from turbos to flowmasters on this and would like to fix the header problem too. or is this a common problem for this model camaro. ive always had first gen camaros before and havnt had this problem.
Old 07-20-2005, 03:30 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
I constantly have trouble getting a spark plug socket in under the headers... eventually you give up and just use a box wrench because it clears things better.
As far as burning boots... get some fiberglass spark plug boot covers, they'll help you out immensely.
good luck
the blonde weasel
Old 07-20-2005, 03:50 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
Well I have to tell you ... your always going to have problems with heads and spark plug wires... I use 90 deg. boots on all my plugs and use good wires (I have Taylors) I used accell before and burned them...
As for getting the spark plugs out the blonde weasel said it all...
Chris
Echeck, Metal-dust in oil, and burning headers!!! IROC_385z Engine 61 03-25-2012 12:29 PM
