Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help With Heads!
Old 01-04-2013, 10:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by gvasquez_81 View Post
Hey there, i need some help deciding on buying a set of heads over what i have now. I can get a set of 441s with a 3 angle valve job 1.94/1.50 screw in studs and guideplates for $200. I heard that these arent bad heads for what they are. Any help?? Would i notice a difference? Is it worth the swap?
My engine:
1980 350 stock bottom end.
882 heads
weaind stealth intake
edelbrock 1405 carb
lunati 442/465 lift cam
msd dist.
1/58 flowtech headers into flowmasters
Thanks any advice is appreciated.
The 441's are a better casting but still have the big smog chambers and small intake port volume. You would notice a change only if your current heads are worn out. Otherwise it's more of a sideways move than an upward move.
You would feel a difference by swapping to a set of production L31 Vortec heads. Takes a different intake, rockers, and center bolt valve covers though.
