Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help With Heads!
  #20 (permalink)
Old 01-05-2013, 08:31 AM
cdminter59 cdminter59 is offline
Help With Heads!
You take a head off. Then take some modeling clay about 1/4" thick place on top of the pistons. Reassembly the head and adjust the valves. Turn the engine over a couple of revolutions. Remove the head and measure the thickness of the clay where the imprint of the valve is. Clearance should be .080 intake, .100 on exhaust.
