Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with Heads
Thread: Help with Heads
Old 04-03-2013, 10:36 AM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Without knowing the piston crown configuration, nobody here can tell you anything. If the pistons you have in the motor now are flat-tops, the static compression ratio could be 10.5:1, if they're 30cc dished pistons, the static compression ratio could be 8.5:1. Until we know the skinny on the pistons, we're flying blind.
