Help With Heads! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2013, 01:17 AM
Help With Heads!
Hey there, i need some help deciding on buying a set of heads over what i have now. I can get a set of 441s with a 3 angle valve job 1.94/1.50 screw in studs and guideplates for $200. I heard that these arent bad heads for what they are. Any help?? Would i notice a difference? Is it worth the swap?
My engine:
1980 350 stock bottom end.
882 heads
weaind stealth intake
edelbrock 1405 carb
lunati 442/465 lift cam
msd dist.
1/58 flowtech headers into flowmasters
Thanks any advice is appreciated.
Old 01-05-2013, 06:23 AM
SSedan64's Avatar
They're slightly better than 882's, so no, not really worth the trouble.
If you can stand a compression increase, a set of 64cc Vortecs would be the ticket.
305 heads or 350 heads on sbc 355 ryan v Engine 5 09-20-2012 10:21 AM
swapping 351W heads for 302 heads babell7738 Engine 10 01-21-2012 10:16 AM
462624 SBC heads vs Patriot heads?? v8hed Engine 2 05-27-2008 09:25 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
