Help with HEI 283 Please - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2013, 03:14 PM
I have a 63 Impala 4 door with a 283 and PowerGlide 2 speed.
I have Edelbrock open air cleaner / Edelbrock Performer 2010 manifold / Edelbrock 1404 500cfm carb and a MSD HEI distributor 8365.
Im new to the distributor tuning and need help with what springs and stop bushing to use?
What timing am I looking for?
Any help with what to do here would be great.
Thanks!
Old 12-06-2013, 04:12 PM
techinspector1's Avatar
Wiki Edits: 326
Stock cam?
Old 12-06-2013, 04:24 PM
I think so but not 100% sure. I would say yes bc it was all original. Motor was rebuilt from a past owner.
Old 12-06-2013, 04:27 PM
Looking to get 36 total I think. I believe it red lines at 5500 RPM
Old 12-06-2013, 05:34 PM
Wiki Edits: 326
OK, the first thing you need to do is to validate the damper/timing tab so you can time the motor with a light.....
http://www.crankshaftcoalition.com/w...op_dead_center
Once that's done, I would put 12* in at the crank and 24* in the weights for a total initial and centrifugal of 36 degrees, all in by 2800/3000 rpm's. The non-adjustable vacuum cannister may provide too much vacuum advance, so I'd use an adjustable limiter for the vacuum advance and try it at all different adjustments to find what the motor likes. MSD part number 84281.....
http://www.msdignition.com/instructi...MSD+Pro+Billet
http://www.summitracing.com/parts/msd-84281
Begin with the least amount of vacuum advance and increase as necessary for max mileage without bucking or pinging.
Old 12-06-2013, 07:26 PM
Ok Only prob is I dont have much room to turn the distributor. I can go about 8 deg advanced before the distributor wire housing starts to hit the firewall.
Would doing 8 deg advanced with 1 light silver and 1 light blue spring giving full vac between 1200-3000 RPM and a red stop bushing at 28deg. Would this give me the 36 total Im looking for?
Old 12-06-2013, 08:22 PM
Wiki Edits: 326
If you encounter physical interference with the distributor body, move all the wires counterclockwise in the cap by one hole. The wires don't care where they are in the cap, as long as they're in sequence according to the firing order.
I have no idea what springs will do what. Experiment with them until you figure it out.
283 crankshaft into 283 south65ss Engine 1 05-08-2007 09:25 PM
stock HEI to Small body HEI now there's problems, need help Doc fat50chevy Electrical 6 07-13-2006 04:19 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 03:38 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 01:48 PM
