Help Help Help 1931 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2006, 08:46 PM
Help Help Help 1931
Hi i just bought a 1931 (A) 2 door in boxes,,,,,and need to find out what is abought the cheapest and that is not to bad to install ,,,,is thair any frount end i can cut out of doner car i know of the mustang 2 frount end any other??????????????????????PLEASE HELP THANKS TIM
Old 06-25-2006, 09:46 PM
As a old Ford owner and a Moderator here,
I would like to WELCOME YOU HERE ...
Most IFS ( Independent Front Suspension ) setups are not inexpensive and as a general rule do not work well under Model A's ... The fenders mount low on a Model A and prevent the upper A arm from being parallel to the ground ... and the front rack system does not fit the car without major cover up in the splash apron area.
I prefer a Straight axle under Model A's and 32 Fords ...
The shiney stuff is non required ...
Old 06-25-2006, 09:58 PM
New Member
Last journal entry: bodywork
i Totally agree with you. Plus they just look so darn good too! Speedway motors sells front axel kits i believe. Im not sure what there website is though.
LT1 in 1931 rod Woody31coupe Engine 6 05-28-2006 09:38 PM
Need YOUR Opinions!! What Do You Think Of My 1931 Desoto Interior Drawing? mistermuscles Hot Rod Art 2 12-11-2005 10:26 PM
1931 Ford model A coupe Pontiacman Engine 2 07-31-2005 01:04 PM
1931 Ford roof metal 1931 steve Body - Exterior 6 12-17-2004 10:05 PM
