help help help !!!!!!!!!!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2005, 07:43 PM
greaser666's Avatar
big boooya
ok today i was driving my car.drove a shifted fine.when leaving parts store would not shift into reverse. so i pushed it backwards.out of the parkin space.put into drive. went into drvie but would not shift out of first.so ibabyed it home. when i got home i pulled into the garage. put in park reved it up and it went forward.when it did that you could hear a clicking noiseso i cut the car off .made sure it was in park with the gaer shifter. cranked it up and it and it pulled forward and made that clicking noise. any ideas before i pull it out and go get a new one by the way its a turbo 350 ttranmisson
Old 04-19-2005, 08:42 PM
broncoII88's Avatar
Do the right thing...
It's all in the fluid
Check your fluid level first. That's why it's clicking. If it's not shifting all of a sudden, then your valve body needs to be cleaned or replaced.
Old 04-19-2005, 10:09 PM
greaser666's Avatar
big boooya
.fluid was full . drained and dropped pan s link had fallen out of that plunger thing in the valve body.and gear slector roller thing was off track with the notched thing in the trans mission and nut was lose
Old 04-20-2005, 03:10 PM
broncoII88's Avatar
You can try tightening that nut, but I would have that trans rebuilt. Sounds like it's a bit old.
Old 04-21-2005, 02:22 PM
greaser666's Avatar
big boooya
well drove the car around to day. after fixing the trans problem shifts fine seems to be good.but i did order a b&m rebuild kit thought.your probally right broncoII88 its probaly ancient
Old 04-22-2005, 08:07 PM
broncoII88's Avatar
Since we are talking about an ancient trans, what year car is that trans in? And what kind of car is it?
Old 04-23-2005, 06:16 PM
mad55chevy's Avatar
cutouts and 7k shifts = cops
make sure your gear selector engages in every gear, and that there is no way your shifter is allowing it to be in 2 gears at once. have someone go through the gears while the car is off, and inspect the shifter detent on the trans.
CJ
Old 04-23-2005, 07:03 PM
nabx22's Avatar
The forward clutch was engaged possibly by a crossleak some where.When the forward clutch is engaged the vehicle will not have reverse and will try to drive in neutral and park .The sound you heard when you revved it in park was the parking pawl trying to hold.
Old 04-24-2005, 12:12 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would not say the t-350 is ancient, old mayb.
It is still used in many applications for racing or street rods
