Help with high/low beam switch on the steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2010, 07:40 PM
My high/ low beam switch does not work in the steering column. I would like to know how to wire either a toggle switch or foot switch for them with out taking the whole steering column apart. It is on a 1994 olds delta 88. Any info would be a great help. Thanks!
Mitch
Old 02-07-2010, 01:31 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Just replace the switch if that is actually the problem...
It's on the topside halfway down of most GM columns actuated by a rod. Look under he dash with a mirror and a light.
Old 02-07-2010, 01:38 AM
ericnova72's Avatar
More for Less Racer
Don't know if it is the same but my Dad and step-brother just replaced this switch on a 1998 Impala, it was a shocking $330 switch, because it has the cruise, interval wipers and dimmer switch all in one. Sucks cause only the dimmer part was bad. I'm so cheap that I would find a way to put it back on a floor switch like the good old days, have heard of it being done but you will need to find a wiring diagram for your 94 Buick to trace the wires.
Old 02-07-2010, 01:47 AM
C-10's Avatar
Revolution Calling
It's on the column.
Check photo below. Arrow is where the rod actuates the switch. Common setup.
Old 02-07-2010, 12:37 PM
Before spending anything on a new switch check the rod. I had the rod pop out of place on one vehicle. Dropped the column (two nuts) and I was able to put it back into place. Problem solved.
Old 02-07-2010, 01:51 PM
shadetree builder's Avatar
Ford Tuff With Chevy Stuff
As C-10 said the switch is on the column, it is adjustable and this is the most common problem with them.
Old 02-07-2010, 02:22 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I agree with Joe, and the other two guys, definitely check it out before spending any money. Could be loose screws, bent rod, or a bad electrical connection. If the switch is bad, those types are less than $20, maybe less than $10.
Steering Column for 1971 Chevrolet C/10 glayman Suspension - Brakes - Steering 13 02-24-2007 02:08 PM
Steering column oldgolpher General Rodding Tech 3 09-23-2006 02:27 PM
Steering column woes gr8art Suspension - Brakes - Steering 6 09-14-2006 03:34 PM
34 ford steering column vette66guy Suspension - Brakes - Steering 3 06-01-2003 08:04 PM
EZ-Wire : Reading Wires From Steering Column horvath Electrical 2 03-23-2003 05:56 AM
