Help with Holley I.D.? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2008, 10:38 AM
Greg T's Avatar
www.krusinklassics.net
My son just picked up a Holley with numbers:
12R-10554B .. And:
R84010-2 .. And:
0454 .
Can anyone tell me what this is? I cant seem to locate these numbers anywhere. I haven't seen it yet, but he tells me the top comes off like an Ede.
Old 09-19-2008, 02:38 AM
one_am's Avatar
holley guru
according to my list (complete holly carb listing from holley) its a 600 cfm 4010 model. the number for the rebuild kit is 37-1541. i actually have one of these carbs. i cant remember the number but its really light weight right? i'm not sure how strong they are as i've never had mine on anything, but i know yours is a 600 so i wouldn't expect it to be really strong on an engine much over 300 ci. not saying it's not going to be strong, but a 750 vac secondary would probably make it look bad. but i am partial to the 750s. sorry i'm blabing. hope that info helped you
Old 09-19-2008, 06:24 AM
woodz428's Avatar
Troll Hunter
Since almost all Holley 4 bbls, with the exception of the Dominator look the same externally....how does a 750 make it LOOK bad? Other than float bowls and some 600s have dual feed bowls, it will LOOK just the same.
If the top comes off, I don't have the numbers handy, it sounds like it may be the limited run Holley made a few years back that is an upgraded Autolite design. They corrected the main Autolite issue, which was limited CFM, but were only produced for a short period.Both sizes look the same. IF it's one of those, they are pretty nice carbs, but apparently orphaned by Holley to focus on their mainstay. Since it has a removable top it's not your typical Holley, they have removable float bowls on each end. Post a pic if you can.
Old 09-19-2008, 02:07 PM
one_am's Avatar
holley guru
why did you ask a question and then answer it immediately? the center hung cathedral floats bowls look better than the side mount. i only said 750 vac as a suggestion to this guy due to the flexibility of application. and trust me his carb looks nothing like a 4150/4160 externally or internally. and your telling me that a tried and true Holley 4150 750 vac is not going to out-perform a limited run remake 600 under almost any situation?
p.s. i meant look bad as in it's going to out perform it. duh
Old 09-20-2008, 12:36 AM
what carb is a 6122-2 or so. it's a 2bbl
Old 09-20-2008, 07:55 AM
woodz428's Avatar
Troll Hunter
There are 2 presumptions you are operating under that discount your sig line as "holley guru". The first is that all 600s come without center hung bowls, that is incorrect. The second is that a 750 will out perform any 600, also incorrect...especially since he didn't mention any engine size. In most cases a 600 will out perform a 750 on 302 size engines or smaller. I use the term "out perform" to describe the total driveablity and not just flat out acceleration. Unless the small engine is built to run just at higher rpms the 600 is a far better choice. I am aware of the look of the now non produced Holley with a removable top, if you reread my post I described it as an Autolite clone(4100),if you look at a 4100 Autolite you will see the similarities.
So in conclusion, mr. guru, I will say that a 750 WON'T always out perform a 600 "under almost any situation". Your comments are a one size fits all mentality that doesn't apply in the real world ...sorry. I am about to remove my 750 from my Cobra and install a 600 that I have set up, because under most conditions the 750 is TOO big. Low speed roll-on is flat unless you down shift and that's with a 6 speed gearbox. I know that the 600 will be more than enough to feed the 351W in the type driving it sees.Maybe I won't have a 180+ top end after that, it might only be 179...big deal. If I decide to run at Bonneville next year, I'll drive it out there with the 600 and install the 750 and see head to head. But on the street I'll take the 600 any day.
Old 09-20-2008, 08:05 AM
Lookin' like a bad deal...
Name:	stupid thread warning sign2.jpg
Parts I.D. Help Bellhousing, clutch/pp, Throw out bearing. isahar Transmission - Rearend 1 10-30-2007 12:50 AM
Part(s) I.d. Help! isahar Hotrodding Basics 0 10-26-2007 10:56 PM
Holley Carb. I.d. Help Needed,,,ford??? GoneNova/406 Engine 7 05-01-2005 06:55 PM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 02:53 PM
need help on holley carb i.d. 81elcamino Engine 3 08-31-2003 07:06 PM
