Applying the foot brake while moving in reverse automaticly adjusts the brakes if everything is in working condition. Or you could always adjust them them by jacking the rear end up and turn the pawl though the access hole with a brake adjusting tool as you turn the wheel by hand....when you feel resistance, you're set.Thats the adjuster at the bottom of the brakes, behind the lower spring. You may just want to pull the drums when you're up on jacks just to make sure the brakes aren't shot!
Yeah, I went in reverse and applied the brake, but it was still doing it. I'm gonna take it to a brake shop I guess, and watch them do it, so I can know what I'm doing. It's easy, I'm sure, once you know how to do it.
| 65 Impala Drum Brakes Question | EazyDuzIt102 | Suspension - Brakes - Steering | 2 | 08-09-2005 04:16 PM |
| Drum Brakes Spring question | JamesRS | Suspension - Brakes - Steering | 2 | 04-12-2005 04:02 PM |
| Drum brakes smelling bad | nitsud08 | Suspension - Brakes - Steering | 5 | 04-11-2005 05:15 AM |
| Drum Brakes | WildOne | Introduce Yourself | 1 | 12-03-2004 09:41 PM |
| Front Disc Rear Drum Brakes | bigjoedo | Suspension - Brakes - Steering | 2 | 07-02-2004 10:16 AM |
