Help-how to overdrive a roots blown engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2010, 10:39 AM
drgnII's Avatar
Does any one out there have any experience with the changes that need to be made to overdrive a blown BBC motor? Are there any basic rules of thumb as to drive ratios and jet size increases? My engine runs great 5% under driven but I would like to swap some pulley's and go 5 to 11% over without damaging something. The car is a drag car so I can't test it on the street . Any help would be greatly appreciated.
Old 03-02-2010, 11:50 AM
techinspector1's Avatar
Wiki Edits: 326
Cubic inches? Static compression ratio? Blower type? Screw type? Roots type? 6-71 Small bore? 6-71 Large bore? 8-71? 10-71? 14-71? Fuel used? Carburetion used?
Old 03-02-2010, 02:02 PM
drgnII's Avatar
It is 458 cu. in., 9:1 static CR, roots 8-71 ,on 110 race fuel with twin 4150 850's and factory jetting.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Buick 430 Engine 70LEBUICK Engine 5 02-24-2010 10:57 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 08:06 PM
750 cfm secondary vacuum enough for a blown engine? 84Z Engine 36 09-20-2004 11:33 PM
Can you add NOS to a carberated blown engine? ChrisMiddleron Engine 1 06-18-2003 06:17 PM
