HELP! How to tune a Mercruiser 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2003, 10:31 AM
Post HELP! How to tune a Mercruiser 350?
Hi,
I am sorry if this is a bit off topic. I have a Chevy Blazer K5 at home also....
I have bought a boat in August without engine. Now I am about to build one. I have a Mercruiser block (Chevy 350), I think with 1:9,5 compression and a Rochester Quadrajet carb.
My stern drive is a Mercruiser Alpha One 1:1,5 (exhaust through the stern drive).
My problem is that this boat (weight 4800 lb) is known to be a very gasoline consuming one, and the fuel price is high in Sweden. Our petrol price is 4.6USD/gallon!, so I want my engine to be so fuel effective as it can.
A modern Volvo Penta 330GXi (330HP Chevy 350 with fuel injection) takes about 0.35gallon/mile in this boat, and that is good. I am glad if my engine will do that.
Max rpm should be about 4600rpm and my guess is that cruising speed will be at 3300-3500rpm (35mph). Max speed will hopefully be about 45mph.
I have been given the following suggestions:
Get a dual plane Edelbrock Performer inlet manifold (not the "RPM" though) and a Crane 113901 came shaft
http://www.cranecams.com/motorsports/sbchevy/113901.htm or perhaps a Crane 113971
http://www.cranecams.com/motorsports/sbchevy/113971.htm or perhaps a Crane 109811
or a CompCamp Xtreme Marine: 12-232-3 (good fuel economy) or: 12-236-3
http://www.compcams.com/Technical/Ca...L/128-169.html
Which of the cams (or another cam) should I get? Is there anything else I could do to get much torque at low and mid rpm (I guess I need the torque from 1200-1300rpm) and still get a decent fuel economy?
Thanks!
Jake
Old 11-12-2003, 11:07 AM
Tow_Truck's Avatar
Try a diesel!!
Hi Jake
Can't help with the cam question, but have you considered putting a diesel in?
I live in the UK and fuel is about $6 a gallon so I know where you're at. In my boat I had the same situation, I fitted a 6.5 diesel chevy motor in. The engine is a straight swap for the 350 chevy. Just physically a little bigger, but all the mounts line up, as does the bell housing and shaft fittings. You do need different exhaust manifolds though.
On paper it sounds like a poor swap, the petrol is much quicker at the top end. But in reality the boat loses about 5-7 mph from the top end but gains 3-4 mph at cruising speed. Resistance through the water increases very rapidly with speed so that extra power is absorbed in a short speed range. A diesel has massive torque and is happy to cruise at 85%+ of its rpm limit. Most petrols cruise at 60% of the rpm limit, normally less due to economy considerations.
These engines also respond well to supercharging and will out perform a normally aspirated 350 chevy in the marine enviroment.
Diesels are much more reliable than petrol engines especially in the presence of water! The fire risk is also much reduced.
Running petrol:
Max=33knts
Cruise=17knts
Fuel=10 gallon/h
Running diesel:
Max=25knts
Cruise=20knts
Fuel=3 gallon/h
Faster cruising and a 70% reduction in fuel consumption!!
In the UK we can use duty free diesel in boats which is only $1.60 a gallon. (I can normally 'find' enough free for an entire season).
Just my two euros worth.
Hmmm,, wonder if I could squeeze one in my 'Stang??
Old 11-12-2003, 11:52 PM
Diesel,... That's a thought. Unfortunately we don't have that tax reduced marine diesel. Our diesel costs about 3.9 USD/US gallon (= 4.7 USD/British gallon) You make it sounds like a good alternative. But I guess that though have to be until at least next season. I have to build my petrol engine first (I do have all equipment except cam and inlet manifold).
Please give me feedback to my specification questions!
Jake
Old 11-13-2003, 12:06 AM
Is the block a later-model one that is set up for use with a factory hydraulic roller cam?
Old 11-13-2003, 12:10 AM
No, I think the block is an older one, perhaps late 70's or early/mid 80's.
Jake
Old 11-13-2003, 08:36 AM
Wrencher's Avatar
Jake, I'd move to the U.S.! LOL, I have a 24' 5000lb. boat 89 w/ 350/260h went to 355, 420h and I don't really notice much change in mileage, except of course with your foot " hand" in it! 63+mph@ 6300, those q-jets are pretty conservative @ cruising speeds. Just MO
Old 11-14-2003, 12:36 AM
Tow_Truck, it sounds almost unbelievably big difference between diesel and petrol consumption. 3 instead of 10 gallons per hour!
Was this at cruising speed? Can the difference also due to other facts (plane threshold)?
Can I use the same stern drive 1:1,5? Or should I have i rebuilt (is it possible to rebuild a Mercruiser Alpha One, gen 1?)
Supercharging... are we talking about turbo or compressor? How much for a supercharger for marine application? I guess the diesel consumption will increase a bit now.... And I guess I have īto rebuild the engine with lower compression....!?
Thanks!
Jake
Old 11-14-2003, 08:01 AM
Jake,
I would go to reedcams.com. The have a series
called the Torque Master and they are the best
marine cams. I would put the Lobe sep on a 114 put
4 degrees of advance in the cam 110 ICA. Intake
I would go with a dual plane with a 1" spacer. If you e-mail reed talk to Dennis, he may be able to get you everything and
save you some freight.
Cstraub
One other thing, with the problem that we have
had with lifters, I would highly recommend getting the
micro finish process on the cam and lifters. It might
be a 100$ extra but its well worth the money as compared
to pulling the engine and putting another cam in it.
Cstraub
