Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with HP
Thread: Help with HP
Old 03-22-2013, 10:02 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Is this a daily driver too? I doubt it will be pump gas friendly with that compression unless you plan on running 93 octane. If it will be mostly for racing, I would change to a 2vr FT piston for more compression. It just depends on what it will be mostly used for. As far as HP, I would guess 325 - 350 with that setup but I may be on the low side. As far as ET, that's only part of it, your 60' time is tied to your ET also and the lower, the better.
