Help with HP - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2002, 06:17 AM
jhulon's Avatar
New Member
Post Help with HP
I am redoing a 1965 chevelle ss when i bought the car it had a 350 in it. ran good with a mild cam. i tore it down and put a new cam in it , a summit cam and lifters 234 244 @.50" lift .488" .510" with a lobe separation of 114. also put a edelbrock manifold with a Holly streetavenger 670 carb. it has 10to1 compression with 76cc heads with large valves and dome pistons. if this helps it has a th350 trans with a b&m shift kit with 4:10 gears in rear end.
What kind of Hp can i expect. Thanks
Old 11-27-2002, 11:29 AM
mustang66maniac's Avatar
Ford Freak
Post
edelbrock performer? id say 320hp.
