Help with a Hydraulic Clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2007, 09:50 AM
onenew32's Avatar
Hot Rodder, and Proud of it
Has anyone out there got a few links to good articles on hydraulic clutch set ups? What master cylinder to use, what slave to use, if any of the hydraulic throw out bearing out there can be made to work. Right now I am dealing with a deuce coupe running a Tremec five speed, using an antique Chevy truck double master and a mid 60’s Chevy truck slave cylinder. I am in bad need of an upgrade. It seems like there was just an article in a mag dealing with this where they used a master and slave from a corvette of some year, but I cant find it now that I need it. Anyone got any links, or can you point me to the right mag?
I might post this in transmissions, and in general knowledge. Mr. Moderator, if I shouldn’t do this in the future, just let me know. Thanks for your help!
Old 07-05-2007, 03:20 PM
RippinRon's Avatar
I didn't know gm used hydraulic clutches in the 60's!?. Howe Racing make hyd. throwout bearings and master and slaves. And MacLeod make hyd. components as well. Hope this helps.
Old 07-05-2007, 04:25 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I got the cylinders from a Jeep Cherokee..work fine..if you have a chev pattern tranny then one of the hyd throw out bearings can work..get those at the usual suppliers..
Sam
Old 07-05-2007, 05:32 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
What you have right now sounds like a 60-62 chev pickup set up. I redid a 60 and the guy wanted a PB booster, so I had to do away with that dual master. I think it was a carquest catalog at a parts store that gave specs for all single clutch masters, and I ordered one that had the same bore as the 60 had, and kept the 60 slave as it was a new one. The replacement master had a large screw on plastic fluid reservoir cover in case you look at some in a book.
Old 07-05-2007, 08:09 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I used an 87 Chev pu bellhousing and clutch slave with an 88 clutch master in the 59 elky
Hydraulic clutch linkage??? 84Z Transmission - Rearend 1 05-31-2005 09:44 AM
hydraulic or mechanical clutch linkage? Pharmy Transmission - Rearend 5 03-31-2004 08:10 PM
Ford Ranger Hydraulic Clutch cvaselaar Transmission - Rearend 3 10-09-2003 07:27 PM
t5 tranny or c6, hydraulic clutch martion Transmission - Rearend 2 08-25-2003 11:29 PM
Mechanical to Hydraulic Clutch??????? Weimer Transmission - Rearend 2 06-21-2003 07:58 AM
