Help with Hydroboost - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2010, 05:28 AM
I was looking at the Bendix hydroboost models, and see that some have reliefs, and other do not. I assume that this is to keep a uniform pressure in the accumulator? I am using a 2002 Camaro PS pump. Does it have an internal relief? Failing this, is there an external relief that could be purchased? My Hydroboost has no relief, or should I obtain another Hydroboost with relief?
Also I have seen different bore sizes for the Bendix Hydroboost models. I understand a bigger bore size will have more boost. Is there a known bore size that works well with something like the weight of a vehicle 3400#?
I am using C5 calipers front and rear.
99 chevy hydroboost problems dhspyder Suspension - Brakes - Steering 1 11-20-2009 07:59 PM
hydroboost bypass OUTLAW00 Suspension - Brakes - Steering 8 10-10-2008 11:15 PM
Custom Hydroboost on '69 Torino blacksunshine Suspension - Brakes - Steering 8 08-03-2007 10:44 AM
More hydroboost questions!? 69ChevelleAddict Suspension - Brakes - Steering 8 07-16-2006 07:55 PM
1967 Chevelle Hydroboost application??? Bad Rat 414 Suspension - Brakes - Steering 2 06-17-2005 12:21 AM
