Help to ID a Borg Warner Trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2011, 10:16 AM
Hi,
Can anyone help me identify the following Ford Borg Warner 4 speed trans? I believe it is from a late 1961 or early 1962 Ford Galaxie bu I would like to know what the "B" signifies???
Thr trans numbers are T-10 B-1 The tail housing is T10B-7
There is an attached tag on trans housing that reads 2A3-D-1
If anyone can interpret these codes for me I would really appreciate it.
Thanks, Bill
Old 12-11-2011, 10:24 AM
Wiki Edits: 85
It is a 1962 T10B transmission.
The B only signifies that it is a T10B transmission as opposed to any other variation of the T10.
Old 12-11-2011, 12:10 PM
T-10 B-1
Thank you for the reply and the help.
Can you be more specific for me? For eample, what tells you it is a 1962 trans? Is it the "2" in the Tag 2A3-D-1?? What do the other numbers on the tag mean?? The "B" must signify something? or it would be a "D" or an "F" or something else?? I know it means a variation of the T10, but what is that variation??
Thank you very much for your help and patience. Bill
Old 12-16-2011, 11:52 PM
Wiki Edits: 85
The 2A3-D-1 is the date of assembly.
No idea what the specifics of the B variation are, so can't tell you. You may have a hard time finding anyone that can answer that question as even the engineers that designed it probably could not tell you even if they were still alive.
All I can tell you for sure is that a T10B is different than a T10T and is different than any other variation.
Borg Warner Trans ricksautorestoration Transmission - Rearend 3 09-18-2010 06:49 PM
borg warner trans thwrench Transmission - Rearend 9 03-01-2009 03:29 AM
Borg Warner 4- Speed TRans Marks Garage Transmission - Rearend 2 06-03-2008 11:29 PM
63 impala borg warner trans. linkage dirtslingerrc Transmission - Rearend 2 10-01-2006 07:58 PM
Borg-Warner Trans MI2600 Transmission - Rearend 0 01-12-2003 11:42 AM
