Help id chevy block - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2013, 07:19 PM
Help id chevy block
I have a chevy 350 block that I need to get a gasket set for, but, I dont know which one I need. I have seen two different sets, one for up to 80 and one for 81-85. The block, I was told, is a gm goodwrench block. It has a suffix of vl. Can anyone help with what year this block is or what the difference in gasket sets are? Thank you.
Old 04-23-2013, 01:03 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I don't find a GM SB with a suffix code vl in any of my references. Is that part of the stamped code from the pad in front of the passenger side head? If not, what makes you feel it's a vl? What's the full stamped codes?
Semper Fi
Old 04-24-2013, 09:38 PM
This is the hand stamped number on the pass side front, vl112832. The block casting number, 14016379, spans from 78 through the 80s so it doesnt help with the gasket kit split.
Old 04-24-2013, 10:26 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
The "V" is a Flint engine.
Casting Date
Small block casting date is located on driver side rear of block on flange forward of bellhousing. Big block on the right side of engine above the oil pan rails.
Casting Date Example: E038 - (E = Month, 03 = Day, 8 = Last digit of model year (1978)).
Month: A = Jan, B = Feb, C = Mar, D = Apr, E = May, F = Jun, G = July, H = Aug, I = Sep, J = Oct, K = Nov, L = Dec
Old 04-26-2013, 10:41 PM
Ok, Ill have to look. But, what if it is a 2 or 3? That wont tell me if its 72 or 82, correct?
Old 07-06-2014, 09:25 AM
Dontecarlo
vl block suffix
Hello, I too have a small bock Chevy engine that has the VL stamped on the block. Mine is VL041800. When I bought the car, it had Target Master decals on the valve covers. Problem is, the engine was built by Dr. Frankenstein. The engine was poorly painted all black. But the block was showing Chevy blue underneath, the intake was the original Chevy orange and the heads were black. The cast number on the back is illegible, so I am lost.
Have you had any luck in identifying the block, as there isn't any listing for VL in any list I have seen, and your post is the only thing on the internet I could find.
Old 07-06-2014, 12:40 PM
Banned
Chevy red-orange
Chevy orange
chevy blue
General Motors Blue
Black
The chevy red was an early color used on some of the 1950's 265 and 283's
Then the chevy orange used from late 50's to mid 70's
Around 77 they used the chevy blue on 350's and 400's, and used GM blue on the 305's
The GM blue was a lighter blue, but not as light as pont. blue. Chevy blue was a dark blue
That lasted till 1982, then everything went black.
If you want to ID the engine do not trust color. Anything can be re painted any color you want it.
Get the suffix code of the front pass side of block in front of head on machined pad..
And the casting # off the driver side rear of block, behind head on flange that trans bolts to.
The Following User Says Thank You to killeratrod For This Useful Post:
Dontecarlo (07-07-2014)
Old 07-06-2014, 07:14 PM
1971BB427's Avatar
Haven't heard of the gasket cutoff dates you're referring to before? Every set I've purchased or seen was either 1955-1986, or 1986 to end. Take a look at the Fel Pro kit. It shows applications from 1955-85.
http://www.summitracing.com/parts/fe...0/applications
Old 07-07-2014, 05:22 PM
Dontecarlo
Name:	monte motor.jpg
Here is a picture of the front tag.
Old 07-07-2014, 05:40 PM
1971BB427's Avatar
Most sources I've seen say that the serial number on a crate engine is just a serial number, and not an indication of when it was built, like engines that came in cars new. CE (US built) and ML (Mexico built) were used as prefixes on crate engines. I'd guess you're correct that the VL is also a crate engine designation, but can't say from where it was used. If you could look the block over, and possibly find a Mexico cast into it somewhere, that might answer where. Afraid you wont be able to answer the year without disassembling it.
Once it's torn down you can determine if it's 1955-85 or 1986 and newer by the rear main seal. If it's 2 piece it's early '85 or older, and 1 piece is 1986 or later.
Old 07-07-2014, 07:07 PM
It goes like this:
1) Pans have different heights to the timing cover Straight edge on gasket rail to bottom of arc:
1.A.) 2-1/4 thin, these will all be drivers (left) side dip stick and 2 pc RMS. will production years 1955 through 1974.
1.B) 2-3/8 thick, these are more complex;
1.B.A) 1975 through 1979 will be left side dip stick and 2 pc RMS.
1.B.B) 1980 through 1985 will be passenger (right) side dip stick and 2 pc RMS
1.B.C) 1986 through end of SBC Gen I, II production will be right side dip stick and 1 pc RMS.
If you know the month of the engine's assembly toward the change over previous year it is not uncommon for late production say 1979 to have a 1980 block and pan, so check before you buy parts if your toward the end of the production year which is the late spring to early summer before the September/October release of the new years production.
Bogie
Old 07-07-2014, 07:14 PM
1971BB427's Avatar
Since all the early 1955-85 gasket sets come with both pan end gaskets (thick and thin) and side gaskets can be flipped to work for either side, then the differences don't mean much during those years.
Old 07-07-2014, 09:46 PM
ericnova72's Avatar
More for Less Racer
SBC Oil pan side gaskets are not symmetrical, and cannot be flipped side-to-side to match either drivers side or passenger side dipstick blocks. Shape near pan corners at each end of the block are very different from one side to the other.
Most gaskets sets cover this by providing oil pan side gaskets with a "knock-out" section to accommodate the passenger side dipstick location in the same set. Sometimes they will use 3 different oil pan rail gaskets, a drivers side, and two different passenger side gaskets in the same full gasket set.
Old 07-08-2014, 06:10 AM
1971BB427's Avatar
My mistake, you're correct. Went brain dead, and I just put mine together about 6 weeks ago! Duh.
Old 07-08-2014, 09:16 AM
Unless you buy a one piece pan gasket in which case you need to be specific as it doesn't come with a choice of ends.
Bogie
Chevy small block and big block bolt lengths zmaxmotorsports Hotrodding Basics 17 03-01-2013 05:55 PM
Cheap block hugger headers for Chevy small block. roger1 Hotrodding Basics 17 01-17-2013 08:27 AM
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
Big Block Chevy ... How much does a block weigh Rob Keller Hotrodders' Lounge 5 03-24-2008 06:10 PM
