Help ID this GM rear end in my '57 Chevy 3100 truck... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2012, 02:03 PM
Hello!
This is my first post, so Hello! from Monroe, CT.
Here's why I'm posting...
This summer, a '57 Chevy 3100 pickup followed me home. It's an older resto that's been worked a bit...400sbc, turbo 400, and a posi rear end. The work appears to be solid and well done.
Anyway, when I bought the truck, the brake pedal sank to the floor, so I pulled apart the brakes, and found that I need an old fashioned brake job, along with a wheel cyl on the pass side. The previous owner (PO), left out all of the self adjusting AND the e-brake hardware, including the strut arm, and I want an E-brake, so I have to find the parts. Here's where it gets interesting, and the reason for my post...
I CANNOT positively ID the rear end, and I have to in order to get the proper brake parts. Here's what I've got...
It's a 10 bolt posi GM rear with 2.73 rear end gears.
Posi clutch is 2 plates between the spider gears held apart by 4 springs
Part # on the gear is 3984825 41 15 (tooth count). There is NO mfg date
Ring gear bolt heads are 3/4"
Carrier # is 32267
Numbers stamped on the front of the pass side axle tube are: NT K 084E
Bolt pattern is 5 x 5
Brakes are 11" x 2"
Wheel cyl has 29471 cast into it
This was a coil spring/trailing arm rear end - top of rear has trailing arm lugs cast into it, and I can see where the bottom mounts were cut off
The driveshaft has 2 u-joint mounted in a coupling at the rear end side
I've been digging for hours, along with posting on the HAMB, and from what I can find, the rear might be from a 71 - 76 GM full size, specifically a full size Pontiac.
Can anyone ID this rear end for me?
Last question - anyone know a vendor who sells GM e-brake strut levers?
Thanks in advance...
Chris
ID:	69682   Click image for larger version
ID:	69683   Click image for larger version
ID:	69684   Click image for larger version
Old 12-09-2012, 05:11 PM
big gear head's Avatar
High Performance Rear Ends
Looks like a GM corporate 8.5 from a full size GM car. IF the posi has 4 springs then it's an after market Eaton that someone has installed.
Old 12-09-2012, 05:30 PM
Searched for images for an 8.5" GM corporate rear, and it does have the lugs at the lower corners like an 8.5. I'll check the pinion nut size tomorrow...if it's 1 1/4", that will ID it as an 8.5, at least according to what I've found online.
Anyway to date it?
What cars would have this rear end come in? I ordered brake shoes from a '76 Impala, and they matched what's in there now, but I don't know if there's any different between Chevy brakes and Buick/Olds/Pontiac brakes.
Thanks...
Chris
Old 12-09-2012, 09:19 PM
SSedan64's Avatar
Should be a Casting # and Date code on the Webs where Center joins Axle tubes.
Also a stamped code on the right axle tube.
Old 12-19-2012, 05:01 AM
Trophyman's Avatar
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
What he said.
Chevy 3100 stock rear end HP capability shep2 Transmission - Rearend 2 06-28-2011 01:45 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
71 chevy truck rear end choppy71 Transmission - Rearend 14 09-23-2005 01:55 PM
rear end for my 36 chevy truck leroux Transmission - Rearend 0 06-13-2002 07:44 AM
Corvette rear end in a 51 Chevy p/u 3100 oldford Transmission - Rearend 2 04-30-2002 12:33 PM
