Help Id this rear end
I bought a rear end for my 52 Chevy 1/2 ton a few years back, and forgot what had bought. I know it's a 10 bolt, but I cannot figure out the stamp on the tube.
2PJ G025 2 Thanks for any help |
maybe dis help
Axle Identification Chart |
Do these pictures not work?
Those look like mono leaf spring perches
Most mono leaf rear ends were 8.2 10 bolt 8.2 10 bolt takes a 1 1/8 socket on the pinion nut and has u-bolt u-joint retainers 8.5 10 bolt take a 1 1/4 socket on the pinion nut and takes flat strap with separate bolt u-joint retainers |
Those are multi leaf perches. This is a '76 or later rear end because it has the 3R yoke. The '71 to '75 8.5 rear ends had a 1310 yoke which used the old external retainers with the tabs in the yoke to center the u joint. The '76 and later 8.5 used the 3R yoke which has internal retainers and no tabs in the yoke. This is not the 8.2 rear end.
| 1953 Buick Special-front end rear end?? | mbjeep | Suspension - Brakes - Steering | 8 | 12-06-2009 06:32 PM |
| stock 63 chevyII rear end vs. s-10 rear end | david6chevy | Transmission - Rearend | 3 | 08-17-2009 04:36 AM |
| Gm 12 bolt truck rear end vs. car rear end | '54 Pontiac | Transmission - Rearend | 6 | 02-05-2009 05:17 PM |
| 4x4 12 bolt rear end same as 2wd rear end??? | Ed ke6bnl | Transmission - Rearend | 2 | 05-24-2008 02:25 PM |
| Ford 9" rear end vs stock 89 chevy truck rear end | jimmy p | Transmission - Rearend | 2 | 12-07-2005 03:28 AM |
