Help to Id Spindle & Hub - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2009, 07:28 AM
tomb23's Avatar
Can you ID this hub ? It was under a 56 GMC PICKUP entire axle was removed The Axle was bent, after having a machine shop replace the kingpins and bushings in a replacement axle I found (from a 55 Chevy 1/2 ton) threw it under the truck connected the drag an steering arms that were on it. Thinking to have it aligned later. 6 years
later now and decided to finish it, I discover the spindles, hubs, and steering will not work on my 56. Apparently they bored the spindles to fit
the 56 axle, didn't tell me that? bump stop does not line up nor the steering links? I wish I had not junked the bent axle, I need to find out what it came off of? It's looking like it may be easier to replace what ever axle it was rather than try to find good 49-54 Chevy hubs 5 X 4 3/4 pattern. If and when you reply I can send pictures to help! Would a great help Thanks
ID:	36740   Click image for larger version
ID:	36741   Click image for larger version
ID:	36742   Click image for larger version
Old 04-04-2009, 09:01 AM
Wiki Edits: 27
other GM?
Guys used to use other gm brake parts,, olds and pontiag on chevies.
Old 01-20-2013, 07:12 AM
496CHEVY3100's Avatar
If you remember the 60s,
Last journal entry: ,
Noticed 5 lug hubs ,came with 6 ,gm used a 6 lug hub from a p/u on the 57 black widow Factory built nascar racer .so i would think they are interchangeable ,have not tried this swap but i think i would check this first ,might be what you need. i recentky sold a 53 gmc pu i bougnt for parts Lots of parts were different would not fit my chevys even though they look similar.
Old 01-20-2013, 04:13 PM
The hubs are 61 to 68 full size Chevy car. It looks like the spindles were machined to use the car hubs.
5X4-3/4 Chevy Hub to 39 Chevy Spindle les88404 Suspension - Brakes - Steering 5 10-31-2007 09:27 AM
complete hub to hub IFS 37 plymouth coupe Suspension - Brakes - Steering 4 07-22-2006 09:40 PM
Mustang II spindle to rotor shim? 41willys Suspension - Brakes - Steering 6 08-05-2005 07:10 PM
spindle question dinger Suspension - Brakes - Steering 1 03-07-2004 05:45 AM
4X4 locking hub ID?!? ramjet Transmission - Rearend 7 01-08-2004 05:36 PM
