Help ID wire into side of T400 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Old 04-27-2011, 05:42 PM
Last journal entry: Bringing home the 401 Nailhead
I have a 364 Buick Nailhead with a Turbo 400. A switch inside is wired to a single pole on the drivers side of the transmission. Previous owner said it has a Hughes 10" 3600 stall converter so I assume this rules out any switchpitch. Any ideas what this wire is for?
    Advertisement
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-27-2011, 06:44 PM
Could be the kick down switch used to drop down into passing gear on a 400 Wire should run up to a switch at the carburetor linkage.
Old 04-27-2011, 06:45 PM
Sixguns's Avatar
its the kickdown solenoid, [ passing gear ] needs to have a throttle switch to supply 12volts to it so the trans downshifts. If you dont have a switch, "Lokar" makes a nice one. hope this helps
Old 04-28-2011, 05:34 AM
Thanks guys. I don't really need a "passing gear" so I assume no harm to leaving it disconnected.
Old 04-28-2011, 06:17 AM
Crosley's Avatar
Global Moderator
Last wiki edit: T-350 rebuild tech
Last journal entry: 1962 Morris Minor 1000
Wiki Edits: 1659
the switch pitch t-400 would have a solenoid on the pump body back side and the kick down solenoid is next to the valve body on the case.
the electrical connector on the case would have two (2) flat prongs to connect to for switch pitch operation
Dont worry how old you are... it is the mileage on your body that adds up.
Recent Transmission - Rearend posts with photos
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Hot Rod Forum : Hotrodders Bulletin Board forums, you must first register.
Please enter your desired user name (usually not your first and last name), your email address and other required details in the form below.
User Name:
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Distributor cap-side plug wire terminals cunningham Engine 6 08-19-2010 02:30 PM
Passenger side dip vs driver side dip in early Nova dirtinla Engine 1 11-20-2008 12:45 PM
Weird problem, rear moves side to side?? Nova_63 Hotrodding Basics 5 09-07-2008 08:47 PM
roller rocker tips off center from side to side awoodman Engine 8 11-17-2007 08:25 AM
How much side to side movement does a rear axle make STATUTORY GRAPE Suspension - Brakes - Steering 9 11-23-2004 06:23 PM
