help ident 6 cyl chev motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2008, 12:40 PM
have a '39 chev and bought a later model 6 (GM) and turbohydro to put into it. the seller didn't know what it came out of and all the codes and casting marks are not crossreferenced by google'n. please tell me where i can find a reference source for this motor. suspect it is a truck motor because it is orange, not blue... the numbers behind the distributor are F0520T TM (second line) C5F4Q1714. thanks for you guidance. mark
Old 04-24-2008, 01:07 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Do a google search for casting # locations. I don't recall ever seeing a GM casting number with any letters in it.
Old 04-24-2008, 01:18 PM
My 2 cents worth
Wiki Edits: 3
1 older book I have indentifies the numbers you have as the vin # and the 3'rd letter is the engine code, but the F is not in the list this book has. I'll look through some other books that I have.
Old 04-24-2008, 03:52 PM
junior stocker's Avatar
6 cylinder I.D.
Any way to post a pic; and include the side covers. Rear sump pan? Was the turbohydro attached to this engine? If the TH was, it's most likely a 250, but, if it was in a truck, there's a good possibility it could be a 292! Try the Inliners site.
Old 04-24-2008, 04:30 PM
My 2 cents worth
Wiki Edits: 3
The only thing I have been able to come up with is the OT at the end of the first sequence you gave, and that looks like a 1969 250 std trans out of a car. There is a TMT listed under 1970 GMC truck 250 std trans, and no TM found anywhere. I suspect it is the TM you have listed might have a T after the TM not stamped good enough to see.
tuning a fuel injected motor novadan Engine 13 03-21-2006 09:21 PM
tuning a fuel injected motor novadan Engine 0 03-18-2006 03:20 PM
Chev LT1 motor VanRodder Engine 5 01-21-2005 10:19 AM
Price for an chevy blown crate motor? Etiene Coetzee Engine 3 07-30-2004 06:45 AM
66 Chev panel motor mounts/possible probs? starek Engine 3 07-11-2002 06:21 PM
