Help identify Chev 400CI engine # - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2010, 02:40 PM
I can't identify the year of my Chev 400 CI engine using the guidance on the internet. It has a serial # on the passenger side block boss just in front of the head. It is 15R452183. I rebuilt it so I know it has 2 bolt main caps & it came out of a Monte Carlo, but I need to know what year it is.
Thanks
Old 11-16-2010, 04:35 PM
bigdog7373's Avatar
Of course it's fast
Those numbers aren't coming up. Get the numbers off the rear of the engine near where the bell housing bolts up.
Old 11-16-2010, 04:44 PM
ericnova72's Avatar
More for Less Racer
Need the block date casting code off the rear bellhousing flange of the block, it will be a 3 or 4 place alpha numeric code(like 12B6, which is "B"= February, "6"=1976).
Block casting code would help also, same area of block, 6 or 7 digits.
# you have posted is just a VIN derivative matched to the car it came from, can't determine year from it, as far as I know. The "452183" matches the last 6 digits of the original vehicles VIN. There should be an application code stamped above the # you gave, on that same front pad, alphanumeric and 8 digits starting with VO, TO, or FO then 3 numbers, then 3 letters. The three letters at the end can be decoded to give the original application.
Being that it is 2-bolt main, it is 1973-1980, the 1970-72 are all 4-bolt main.
Old 11-17-2010, 06:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
THIS thread has info on ID'ing whether the engine is a 400 to begin with.
The date code on blocks and heads is usually a single letter followed by a series of numbers. It breaks down like this:
A- January
B- February
C- March
D- April
E- May
F- June
Etc.
The first set of numbers is the day of the month. This can be 1 or 2 numbers.
The second set of numbers (the sets can be separated by a space, but sometimes they are right next to each other) shows the year and can be (most often) 1, and up to 4 digits long.
Example:
  • B20- Feb. 2 of '70, '80, '90
  • B208 = Feb. 20 of '68, '78, '88, '98- this is the format most often seen on blocks and heads.
  • B2078 = Feb. 20 of 1978
  • B201978 = Feb. 20 of 1978
If you look at the casting number and casting date, you can figure out what the actual year and app for the casting. The SUFFIX can also help, just be aware the suffix can be lost when the block is decked and can be forged.
Old 11-17-2010, 07:06 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Thanks
Your 15R452183 deciphers as:
1= Chevrolet
5=1975
R=Arlington final assembly
452183= Last six digits of vehicle engine was installed in
The 1975 is the model year vehicle the engine was originally installed, depending on the date (month/day) of the vehicle assembly the engine could be a 74 or 75.
The specifics listed in the above post's will narrow it down between the two.
Old 11-17-2010, 02:31 PM
ericnova72's Avatar
More for Less Racer
Thanks to 1ownerT for the info , I wondered if the "5" in the #'s he posted could siignify 1975, and you provided the answer.
I learned something new today
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Identify 350 chev engine adantessr Engine 5 07-11-2010 05:44 AM
How Does A Thermostat Work? cobalt327 Hotrodding Basics 16 03-16-2010 07:32 AM
283 chev engine mods Holden HG Ute Engine 10 09-26-2003 06:34 PM
Valve adjustment 305 chev engine Oneshot Engine 2 09-21-2003 09:22 AM
