Help! Identify Older Crower Cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2008, 06:34 PM
in2classx's Avatar
DR. SHOCK
I Have An Older Crower Cam That I Can't Find Any Information On Do You Know Anything About This Crower Cam # X7479
Thank You
Old 05-17-2008, 10:43 PM
techinspector1's Avatar
Wiki Edits: 326
If nobody gives an answer, call Crower.....
http://www.crower.com/misc/contact.shtml
Old 05-18-2008, 06:29 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I have a NOS Crower that I could not find specs for, and Crower does not keep records past 15 years (so I am told by another person)
I came here for help and the HR guys suggested I use a dial indicator, a set of V blocks, and a degree wheel.
I made a chart, plotting the lift at what degree, plus the duration. (by the way,I was told to use a lifter to get a more accurate reading; so I set up an old Ford lifter on some angle iron)
We also found out that hyd cams have a very short "lash ramp' at the very beginning, compared to a solid cam. Once you figure out it is a solid cam, you can get the valve adjustment specs from those "lash ramp" measurements.
Sounds like a pain, but if you can't get Crower to ID it, then you need to try it yourself
My cam turned out to be a hyd, with .577 lift and 277 duration
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
What cam specs work well with centrifugal Superchargers? hotrodf1 Engine 1 09-22-2007 04:21 PM
how do I identify an a fter market cam? jesse01 Engine 10 02-22-2005 09:55 AM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
Can you identify the vendor of this cam part # txsfld Engine 5 09-19-2002 08:28 PM
