Help identify this rack - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2010, 09:39 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Hi, I have a power rack and pinion unit that I need to identify so I can get hoses. It came on an used aftermarket sub-frame and the previous owner doesn't knmow what it is either ??? There are cast numbers on the main housing of RF-E9SC-3550-AA, and 2 sets of stamped numbers/letters of SPR-DL and 89K06C. I removed one of the 2 feed tubes and it seems to be a flare tube with a white teflon or rubber seal ring. It will be mated to a 98 GM F-body ps pump. I don't have any goods pics on hand but I can take some, if a visual will help. Any help will be appreciated !!
Old 09-04-2010, 11:14 AM
Pics for those you like a visual...
Old 09-04-2010, 12:43 PM
What is the spacing on the rack mounting bolts?
Old 09-04-2010, 03:51 PM
15 1/2" center to center
Pressure port is 9/16 X 18 thread and return is 5/8 X 18 thread and they both will be flare tube with flat bottom to seat on a teflon washer.
Hope that helps..........
Old 09-05-2010, 12:24 AM
I believe you have a 74 to 78 Mustang rack. And I believe you will find that the fittings have a extended tube with a Teflon O ring seal. You can get adapter fittings from Weatherhead to use standard JIC fittings.
Old 09-05-2010, 09:05 AM
Definately not a 74-78 mustang. The hose end sizes indicate ~88~ T-bird rack. Spent an hour yesterday at the local Car Quest and looked at a 74-78 rack and hoses they had in stock and verified they are not what I have. They didn't have any of the T-bird parts in stock...not enough demand...
willys has rack and pinion davedeltadog Suspension - Brakes - Steering 5 03-31-2013 11:24 AM
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 12:59 PM
have you switched to manual rack ? TheCiscoKid Suspension - Brakes - Steering 15 07-24-2009 10:47 PM
My Rack is to small iceman36 Suspension - Brakes - Steering 10 01-12-2008 05:31 PM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 01:53 PM
