Help identify this rear end please - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2010, 04:12 PM
Mitchman's Avatar
Grand Master of the Universe
From under a '34 coupe 'glass car. Clearly leaf springs. Any idea what the axel is from?
For 10 bonus points.... Any idea who made the chassis? I know it's not much to go on, but the car is 6 hours away. Trying to make a 'go see it' decision.
Thanks
Ahhhh! Just for fun now - car just sold.
Old 11-21-2010, 05:13 PM
big gear head's Avatar
High Performance Rear Ends
Looks to me like a 7.5 10 bolt from an S truck.
Old 11-22-2010, 03:20 PM
fast68's Avatar
likes chevy trucks & boobies
definitely common GM axle
if the little things at 5 and 7 o clock positions are just little fangs or teeth then its the 7.5 or 7.625 yep
s10 camaro caprice monte cutlass regal grand prix elky malibu and billions more cars over the years.
if they are not little teeth and instead are big 90 degree corners solid then its an 8.5"
its hard to tell with the shiny paint for sure but it appears they are tiny fangs, so is not 8.5" then
Old 11-22-2010, 03:57 PM
It's not the 8.5. The cover is oval shaped. The 8.5 has a round cover. This is the 7.5. The only question is what did it come out of. My guess is a S truck.
Old 11-22-2010, 06:16 PM
junior stocker's Avatar
Look closely at the 5 and 7 o" clock areas, and you can see the "fangs"; it's the small 7.5/7.625 corporate GM rear end.
Old 11-24-2010, 05:47 AM
looks like a S-10 rear we put one in my dads 41 plymouth. If it were a G-body you would be able to see the mounts on top where the upper control arms went.
Identify rear end jamn50 Transmission - Rearend 6 11-28-2010 09:29 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
68 Camaro Rear end Curtis Thornton Transmission - Rearend 14 03-12-2008 05:19 PM
Rear end ID ctown Transmission - Rearend 1 05-15-2006 10:20 AM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
