It's on a 2000 GMC Sierra 5.3 Vortec engine and auto transmission. I mounted my '56 Burb body on the rolling chassis and there are five connectors that does not have a mating connector on the chassis so I'm thinking they were connected to the cab. Can anyone help in identifying what they connect to so I can finish wiring up the Burb? Thanks
Like looking for a needle in a hay stack. Here is what I was able to find.
Picture 4 - 3 wires brown/white, pink/black, red is camshaft position sensor.
Picture 1 - connector on left green wire and black wire - A/C compressor clutch connector. The other connector is shaped like C350 Engine Harness to 4 Wheel Drive Harness (NP8/NR4) however the wire colors don't match. Striking out there.
Picture 3 - 3 wires grey/black, Black/white, brown -C153 4 Wheel Drive Harness to Engine Harness (NP8/NR4)
Looked at every connector view for this truck and that is what I was able to find. Hope that helps.
I had no luck finding the connector in picture 2 and I went through every connector in the service manual. Probably saw it and missed, spent an hour looking and ran out of time.
Where was it located? Might help narrow down the systems and I could take another stab at it.
Now. I want to check to see if the 'burb you are building is in your project journal. Really wondering what you are putting together.
I've been tinkering on this for the last four years but keep starting on other projects. Then I decided that I needed to finish it for next season's runs.
Here's a pic of the burb.
BTW could that mystery connector be for the under the hood light? There's actually two wires not three as I previously stated.
At any rate, I'll start connecting the cab wiring today and try to start the engine within the week, so hopefully that connector is not a critical one that prevents the engine from starting.
Thanks again and good luck on your Burb.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
