Help Identifying 2000 GMC Wire Connector - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2004, 10:18 PM
Seon's Avatar
Question Help Identifying 2000 GMC Wire Connector
It's on a 2000 GMC Sierra 5.3 Vortec engine and auto transmission. I mounted my '56 Burb body on the rolling chassis and there are five connectors that does not have a mating connector on the chassis so I'm thinking they were connected to the cab. Can anyone help in identifying what they connect to so I can finish wiring up the Burb? Thanks
Pics
Old 10-23-2004, 03:56 AM
advanced design's Avatar
Remember, this is to be fun!
Last journal entry: Lead Joint replacement
Seon,
Same Seon at Chevy Duty? Where are the connectors located and what sizes are they? What do they look like?
Old 10-23-2004, 10:32 AM
Seon's Avatar
Yep, the same Seon.
I posted the pics with description of where the wires are located. Please clip on "PICS" in the above post. Thanks
Old 10-23-2004, 01:48 PM
Seon,
Like looking for a needle in a hay stack. Here is what I was able to find.
Picture 4 - 3 wires brown/white, pink/black, red is camshaft position sensor.
Picture 1 - connector on left green wire and black wire - A/C compressor clutch connector. The other connector is shaped like C350 Engine Harness to 4 Wheel Drive Harness (NP8/NR4) however the wire colors don't match. Striking out there.
Picture 3 - 3 wires grey/black, Black/white, brown -C153 4 Wheel Drive Harness to Engine Harness (NP8/NR4)
Looked at every connector view for this truck and that is what I was able to find. Hope that helps.
Old 10-23-2004, 06:14 PM
Seon's Avatar
Hi Advance Design.
After reading your reply, I checked the connectors again and here's what I found.
Pic 1. Both are connectors for the A/C . One to the High Pressure switch. The other is for the compressor clutch.
Pic 2: I couldn't figure out what this is for???????????????
The connector has "PED 47 on it.
Pic 3: I think this is for the 4 wheel drive connection
Pics 4: this is for the camshaft postion sensor.
You've been a big help. Thanks so much.
Now if we could figure out what the connector in Pic 2 is ???
Old 10-23-2004, 06:29 PM
Seon,
I had no luck finding the connector in picture 2 and I went through every connector in the service manual. Probably saw it and missed, spent an hour looking and ran out of time.
Where was it located? Might help narrow down the systems and I could take another stab at it.
Now. I want to check to see if the 'burb you are building is in your project journal. Really wondering what you are putting together.
Old 10-23-2004, 07:54 PM
Seon's Avatar
I've been tinkering on this for the last four years but keep starting on other projects. Then I decided that I needed to finish it for next season's runs.
Here's a pic of the burb.
Old 10-24-2004, 07:28 AM
Very nice. Thanks . I have a '48 Suburban to build and will start as soon as I finish the '35 Master coupe. So many projects, so little time.
Old 10-24-2004, 07:41 AM
Seon's Avatar
Originally posted by advanced design
... So many projects, so little time.
Amen to that
BTW could that mystery connector be for the under the hood light? There's actually two wires not three as I previously stated.
At any rate, I'll start connecting the cab wiring today and try to start the engine within the week, so hopefully that connector is not a critical one that prevents the engine from starting.
Thanks again and good luck on your Burb.
