-   -   Help with identifying carb (http://www.hotrodders.com/forum/help-identifying-carb-97495.html)
Cheap5.0 09-06-2006 04:03 PM
Alright, i have a mystery carb and i don't know where to start. Where do i find its identifiers? Part #'s and such? Once i have these i will post them up here or google them.
larryblack 09-06-2006 05:21 PM
If you can post a pic, you would get a bunch of replies.
Look on the choke horn and the pass side for #'s. Some carbs have numbers on the base plate by the hold downs.
If you cannot post a pic, find all of the numbers and post them with a description of where on the carb the number is located.
You might also let us know how many barrels it has while you are at it.
chevmal 09-06-2006 06:11 PM
Carb
If its a holley ,go to mor tec site, they have all of the Holley list numbers, Al
Cheap5.0 09-06-2006 09:46 PM
thanks guys, i will take a pic tomorow and also look for the numbers.
Cheap5.0 09-10-2006 03:39 PM
still have not had much time to get a light out there, but its a 2 barrel holley. I figure the 305 was probably a complete crate engine from some cheapo rebuild place, so the carb is probably a stocker as well. Unless there were some awsome 2 barrel holleys produced, i don't need to know much more about it.
