Help Identifying Holley Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2009, 09:02 PM
Tubbed357's Avatar
81 Monte Carlo SBC 357
Well I am having issues with my carb and im wondering if its too small so I am trying to find info on this carb but I cant. The number is LIST-7163
Thanks in advance
Old 10-03-2009, 10:09 PM
kleen56's Avatar
Thanks in advance
What you have is a 600 CFM Holley Vacuum Secondary Carb List #7163. This carb was original equipment on a Ford Marine 351 engine.
Old 10-03-2009, 10:17 PM
Tubbed357's Avatar
Ahh i see, how did you find that information about the carb. I tried there site and couldn't find anything. But anyway what i want to ask is,,,, is it a bad idea to run a marine carb on a street motor? the issue i was having was it seemed like the motor wasn't getting enough fuel when it was under load. It would kind of cut out. Could i get different jets or something
Old 10-03-2009, 10:22 PM
S10 Racer's Avatar
http://www.warsprints.com
It's not on the Holley website. That info is posted here http://my.boatus.com/forum/forum_posts.asp?TID=64377
Old 10-04-2009, 11:24 AM
kleen56's Avatar
The carb you have is basically the same as the 4160- 600 CFM vacuum secondary carb. The carb may be too small for the engine you have, or may only need jetting. Timing is a big factor on performance and I'd check that as well. If the timing is good, I'd pull a spark plug and check to see how the engine is running. If it's too lean (not enough gas), the plugs will be light gray or white in color. If the plug is a brown, that's OK, Black and sooty is too rich. If your running lean, I'd try a bigger jet in the primaries and see if that helps. You can run a marine carb on your vehicle. I would consider getting another carb eventually.
Old 10-04-2009, 11:47 AM
Tubbed357's Avatar
Ok sounds good, the timing is dead nuts so im pretty sure it isn't that so ill check the plugs. For some reason i haven't done that yet haha
Ohh forgot to ask, since i haven't done a plug check in a while i kind of forgot how the process went. Dont you have to have a clean plug and do a quick WOT run for a sec then immediate shut the car off. Not sure exactly if thats right though. Or do i just pop a plug out and look at it haha
Old 10-04-2009, 05:09 PM
Tubbed357's Avatar
Well today i tryed to work out the bugs and thought i had it figured out until i started it and gave it some gas in gear. I really need some help here cause i have tryed tons of things. To give you an idea of what its doing it kind of sounds like it is hitting a rev limiter but obviously it isn't.
Old 10-04-2009, 05:14 PM
poncho62's Avatar
Wiki Edits: 5
like you are running out of gas.......Fuel pump, clogged filter, kinked or too small gas line....could be a lot of things
Ontario Rodders
Old 10-04-2009, 07:57 PM
Tubbed357's Avatar
Well its defiantly not a kinked line or a clogged fuel filter, all the simple things i have already went over. I prolly should check my fuel pressure next..
Old 10-05-2009, 12:06 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Also remove any filter in the bowl. They are restrictive. Use an inline filter instead.
Old 10-05-2009, 12:44 PM
Tubbed357's Avatar
Ya i would but i did that already haha, i thought it would make a big diff cause like you said it was very restrictive. But unfortunately no change
Old 10-05-2009, 05:43 PM
Tubbed357's Avatar
Hey would it help you guys if i made a vid and put it on photobucket or something. I think im going to get a bigger accelerator pump nozzle
holley carb backfires threw carb talleyho Engine 61 05-25-2011 10:03 AM
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 02:28 PM
Edelbrock or Holley Carb. for my street/strip Truck anthony4401970 Engine 12 02-26-2008 12:03 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
Holley Carb Tuning Coleman396 Engine 4 07-19-2003 10:03 AM
