HELP identifying Holley Carb
Any one know what type of holley carb this is ON THE AIR HORN IT SAYS
(LIST-4118 1994 :confused: I NOW ITS A DOUBLE PUMPER |
Not to burst your bubble ... but are you SURE it's a double-pumper? If I'm reading the Numerical Listing correctly, it says it's a 725 CFM 4150 series with a yellow spring in the vacuum secondaries. http://www.holley.com/data/types/pic...rb%20intro.jpg IMO, a VS carb is better for MOST street-driven vehicles (especially with an automatic trans) anyways.:thumbup: |
I seem to remember it being an older model from the late 60s or early 70s,maybe check oem?
I just took another look.
Primary fuel bowl #134-103 Secondary bowl #134-102 Which are center-hung fuel bowls. (That's a GOOD thing.) The primary bowl is listed as possibly being on a MARINE carb? http://www.holley.com/data/products/...ium134-102.jpg In any case ... both bowls will have accelerator pumps attached to the bottom of BOTH bowls if it's actually a "double-pumper" Edit: Sorry, I was typing this while you posted a response to my last one. My aplogies ... not trying to be argumentative. :D |
I like Holleys because I find them pretty simple to work on. Your Holley 4418 is supposed to be 735 CFM, which may or may not be a good thing, depending on engine displacement, RPM range, and intended use. |
Here' an actual CFM calculator which accepts some variables (like Volumetric Efficiency). |
depends what you call mild? A 650 X is a great little carb.also depends on what intake you are using.
650 would work very well on a performer and mild 350 with headers.
From http://mustangtek.com/4150/4118.html: http://mustangtek.com/4150/images/4118002.jpg |
| All times are GMT -6. The time now is 03:51 AM. |
