HELP identifying Holley Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2012, 02:56 PM
Any one know what type of holley carb this is ON THE AIR HORN IT SAYS
(LIST-4118
1994
I NOW ITS A DOUBLE PUMPER
Old 10-08-2012, 03:33 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
(LIST-4118
1994
Not to burst your bubble ... but are you SURE it's a double-pumper?
If I'm reading the Numerical Listing correctly, it says it's a 725 CFM 4150 series with a yellow spring in the vacuum secondaries.
IMO, a VS carb is better for MOST street-driven vehicles (especially with an automatic trans) anyways.
vinniekq2's Avatar
I seem to remember it being an older model from the late 60s or early 70s,maybe check oem?
Old 10-08-2012, 03:45 PM
yea is a double pumper
Old 10-08-2012, 03:47 PM
so will i be better off keeping my 600 edelbrock carb??
Old 10-08-2012, 03:52 PM
66GMC's Avatar
I just took another look.
Primary fuel bowl #134-103
Secondary bowl #134-102
Which are center-hung fuel bowls. (That's a GOOD thing.)
The primary bowl is listed as possibly being on a MARINE carb?
In any case ... both bowls will have accelerator pumps attached to the bottom of BOTH bowls if it's actually a "double-pumper"
Edit: Sorry, I was typing this while you posted a response to my last one.
My aplogies ... not trying to be argumentative.
Old 10-08-2012, 03:59 PM
66GMC's Avatar
You'll get a varied response to this question.
I like Holleys because I find them pretty simple to work on.
Your Holley 4418 is supposed to be 735 CFM, which may or may not be a good thing, depending on engine displacement, RPM range, and intended use.
Old 10-08-2012, 04:03 PM
Originally Posted by 66gmc View Post
you'll get a varied response to this question.
I like holleys because i find them pretty simple to work on.
Your holley 4418 is supposed to be 735 cfm, which may or may not be a good thing, depending on engine displacement, rpm range, and intended use.
i was going to put it on a mild built sbc 350 bore 40 over
Old 10-08-2012, 04:22 PM
66GMC's Avatar
Holley's Interactive Carb Selector recommends a 600 to 650 CFM w/ vac secondaries for a "mildly modified" 350 with a max RPM of 6,000 in a vehicle weighing more than 3100 lbs ... etc.
Here' an actual CFM calculator which accepts some variables (like Volumetric Efficiency).
The Following User Says Thank You to 66GMC For This Useful Post:
the82elco (10-08-2012)
Old 10-08-2012, 04:32 PM
vinniekq2's Avatar
depends what you call mild? A 650 X is a great little carb.also depends on what intake you are using.
Old 10-08-2012, 05:26 PM
Edelbrock performer RPM INTAKE
Old 10-08-2012, 05:46 PM
vinniekq2's Avatar
650 would work very well on a performer and mild 350 with headers.
The Following User Says Thank You to vinniekq2 For This Useful Post:
Old 10-09-2012, 11:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
(LIST-4118
1994
A Holley 4118's not a double pumper- it IS a dual feed, however- a lot of guys get this mixed up sometimes. Has vcuum secondaries, was originally a performance aftermarket carb for the 289/302 sized Ford. As long as the linkage can be worked out for the engine you want to use it on, it'll work fine being as how it's a vacuum 2'ndary carb. Might take some tuning, just like any carb.
From http://mustangtek.com/4150/4118.html:
The Following User Says Thank You to cobalt327 For This Useful Post:
the82elco (10-09-2012)
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
Help Identifying Holley Carb Tubbed357 Engine 11 10-05-2009 05:43 PM
Help with identifying carb Cheap5.0 Engine 4 09-10-2006 03:39 PM
Identifying TriPower Holley Carb Setup 66 CT Stang Engine 5 09-07-2006 12:17 PM
Tuning and identifying a edelbrock carb junkyardjeff Engine 2 01-02-2006 06:23 PM
