Help Identifying Small block please??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2007, 10:50 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Hey Y'all,
I am getting more "ED u mukated" in reading blocks but this one I got has some new markings to me can you help?
The block casting # is a typical 3970010 but there is a big 25 embossed there.
Now on the back of the block on the pass side by the fly wheel there is a
010
020 {is this a high nickle block ? }
& on the other side there is a H41
On the or above the oil filter mount there is :
371
386.. or 388 {its hard to read until I can get to clean on it}
And 118 13 N the "118 & the N" are embossed" but the 13 is stamped .
Also they are upside down all the ones I have seen have been like regular reading where the motor is in place .
....last one
On the front of the block is these #'s: 0409CNN
Well thanks in advance for the help.
Rob
ID:	24774   Click image for larger version
ID:	24775   Click image for larger version
ID:	24776   Click image for larger version
"SlowRide66"
"Illegitimis non carborundum"
Old 10-09-2007, 11:06 AM
302 Z28's Avatar
According to the information I can find the block can be any 302, 327 or 350 from 1969 to 1980 the "CNN" stamp tells me it's a 1970 block 2 or 4 bolt main, 350cid, 250hp 2 barrel carb.
Vince
Old 10-09-2007, 12:41 PM
As a side note ...
every SBC engine code I ever saw that was just 2 letters ... was a 69 and back engine. Three letters started in 1970 ... as far as I can tell.
Old 10-09-2007, 06:25 PM
MI2600's Avatar
Member# 3287
Not necessarily. I've got a '65 327 marked "HCH".
Old 10-09-2007, 07:12 PM
Rob Keller's Avatar
Wiki Edits: 38
Well screwed again
It was traded for labor {years ago}
It was supposed to be a .030 4 bolt main well its a 2 bolt but it does look like it has new pistons .@ least from the bottom.
is there any way to check to see if it has over sized pistons with of pulling off the heads?
Thanks
Rob
"SlowRide66"
Old 10-09-2007, 07:23 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Rob,
You have a 1970 Camaro, CNN, 350-250 HP with a turbo 350 trans. As for the 010 casting number they made 1000's of them everything from high performane to base motors and they came with 2 and 4 bolt mains. It's a good engine with good compression ratio.
Old 10-09-2007, 08:11 PM
010s are good blocks Get you some 4 bolt caps and add a cam etc
Shane
Old 10-09-2007, 09:14 PM
Rob Keller's Avatar
Wiki Edits: 38
It was supposed to have been rebuilt shortly before & got it & it was supposed to be slightly cammed .
I'm Putting it in my 85 BURB with the 700R4 4:10
I hope it don't need premium to run on .
I took it out of a van put it in a Elcaminio now its out again no mileage added to it [not counting how many times I have moved it ]
Going to put freeze plugs gaskets & that stuff & stuff it in the hole & see what it does.
I might pull the timing cover to peek @ the cam.
Ill take some better pixs soon
thanks alot
Rob
"SlowRide66"
how strong is a 350 small block ChevyVan Engine 18 01-04-2007 11:27 PM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
Decoding Ford Small block hotrodgs Engine 16 05-14-2006 05:15 AM
small block or big block southrncuz1816 Engine 16 03-19-2006 07:40 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
