Help identifying steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2011, 01:25 PM
Hello!
So, I would like to identify the steering column in my '57 Chevy Suburban, here is what I know:
The truck has a '77 Camaro front clip, with a 250ci engine; all stock interior apart from a '95 Chevy truck bench seat;
It is a tilt column, with ignition key and auto shifter on the right hand side;
on the left hand side, there is the signal stalk, chrome with a black (bakelite?) end;
on the right hand side, there is the usual GM 4-way flasher switch (push in the middle, pull on the outside);
The truck came with an ugly black plastic Chevy steering wheel, unknown origin;
I was able to mount a '56 Chevy car steering wheel with no issue, even the horn works!
The neutral safety switch for a '77 Camaro does not fit right;
The column has been painted the same gray colour as the dashboard.
Can anyone help me?
Is there an ID number somewhere?
Thanks!
Chris
Old 01-25-2011, 02:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Post a pic and maybe someone can tell from that. JMO
Cole
Old 01-25-2011, 09:05 PM
Chris;
I think I have the same one in my '94 Silverado. check the neutral safety for a Silverado, Sierra, or Yukon 1992-1995 and see what you get.
Good Luck
Hank W
Old 01-26-2011, 09:11 AM
Originally Posted by wave1957
Hello!
Can anyone help me?
Thanks!
Chris
Unfortunately, it sounds like every GM column built since 1969. Is the dimmer on the column or not? That will at least narrow it down.
Old 01-26-2011, 11:07 AM
No, the dimmer is not on the column.
The wiper/washer or cruise are not on the column either, by the way, so this could narrow it down a bit more?...
Old 01-26-2011, 11:25 AM
Sounds like 1969-1979(ish) GM. Hard to tell more without seeing it. I would have thought that all of those used the same neutral safety switch.
55-59 steering column LS EXPRESS Hotrodding Basics 1 10-09-2010 01:44 PM
Help identifying steering column Aerotech General Rodding Tech 11 06-26-2010 02:38 PM
need steering column grandpasdelight Introduce Yourself 3 06-09-2008 10:38 AM
Steering Column lakota Suspension - Brakes - Steering 3 09-19-2004 08:57 PM
How do u take out steering column? ChrisMiddleron Suspension - Brakes - Steering 7 07-24-2003 07:25 PM
