Help with IDing my carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2012, 08:42 PM
I bought 2 holley carbs from a guy that he thpught they were 650 cfm double pumpers. I have found the list numbers on them but our parts house in town that the owner has been rebuilding carbs for longer then i have been alive.the numbers are 1850-5 0681 and 1850-3 0132. I was wanting to see if anybody could help me find out what the cfm is on them and what kit number i need i want to put a trick kit in one of them if they have that number also.
Thanks
Old 08-10-2012, 12:46 AM
moss
here's link at Holley
Holley Performance Product Search
1850 is a 600 cfm vacuum secondary.
some of them are blower carb's and
there's something funny about them.
have a nice day!
Old 08-10-2012, 01:01 AM
327NUT's Avatar
RH......the 1850 series carb is a very popular mild build unit. In no way is it a "double pumper" and it's not even a dual feed type carb but it's been around a long time. As said prior it's a 600 cfm and would be a decent carb for a 283-327 sbc or 289-302 sbf.
Old 08-10-2012, 02:14 AM
JeffB's Avatar
As for the -3 and -5 the higher the number the newer it is, but doesn't make it any better.Good carbs and EZ to work with be sure and visit the Holley web site for more tuning tips.
Old 08-10-2012, 05:32 PM
my bad, here's the tunnel ram or blower carb.
Holley 4160 Dual Quad 450 CFM Carburetor - Speedway Motors, America's Oldest Speed Shop
Holley List 4779.
word is it won't work too good as a single carb.
i don't see why not , but whatever.
those 1850's should work ok, but you ought to go through them.
have a nice day!
Old 08-11-2012, 12:45 AM
r h moss
well, here's your Trick kit.
Holley Performance Products Trick Kit Carburetor Rebuild Kit*37-933
about $100.
the renew kit is about $25.
get one of those, Gunk carb dip & Gumout carb cleaner
and away you go!
have a nice day!
Old 08-12-2012, 12:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Holley List 4779.
have a nice day!
I'm not exactly sure of what it is you're saying- but the carb linked to isn't a 4779. A 4779 is a common double pumper, 750cfm. It's a 4150, not a 4160.
The 9776 linked to is one of a very few mechanical secondary non double pumper 4160 carbs and it isn't made for single carb use. Another mechanical secondary non double pumper is the 4224 660 cfm "center squirter" carb- also originally made for dual-4 use.
Old 08-12-2012, 12:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
As has been said, you have a pair of 600 cfm vacuum secondary 4160 Holley carbs. They are commonly used on milder builds up to 350 cid on dual plane intakes.
Look up the factory specs along with the Renew and Trick kit numbers HERE.
Need help IDing this 69ChevyC10 General Rodding Tech 8 02-15-2010 06:07 PM
Help IDing motor Crazy Fast on Ice Engine 3 02-17-2009 11:15 AM
IDing a car raidmagic Hotrodding Basics 2 10-17-2006 12:00 AM
Need Help IDing Muncie Barz51 Transmission - Rearend 1 05-08-2005 09:29 PM
IDing Engine WheelMan Engine 5 02-15-2003 02:26 PM
