Hi Guys
Can someone help me with a little question I am currently restoring a mini cooper which I have stripped back for a bear metal re-spray. The seams which join the panels of the mini have been cut out and welded. These welded areas will need to be reshaped using filler. My question is - for these areas should I bog dirrectly to the bear metal or to the 2 pot eatch or do I need to use something else before I bogg. Some people have told me that if I bog directly to the metal, the car will rust under the bog. These same people have also told me that you cant bog onto eatch because it wont hold.. So you can understand my confusion Also when they welded the seams the used a very hard grey filler (looked like something like Need-IT) do you know what this stuff is called Cheers Tim |
I find it amazing that we speak the same language and have the same hobbies and intrest, and yet we sometimes can not under stand what we are saying. I have a real good friend that lives in OZ. When i hear his pals talk,i can`t understand a word they are saying , and have to ask Jon, (my friend) what was said.
Slider in Wa. |
Thanks for the reply guys
The areas which i have to fill are quite large, is this going to make any difference. would you etche overtop of the filler I hope this is easier to understand Cheers Tim |
Filler shouldn't be used for filling large areas, only for smoothing. Usually fillers should not be over 1/8" thick. Using gobs of filler is just a bad idea, sure it will hold up for a few years but with the drastic tempretures in new zeland it won't be long before you exsperience some kind of problem. As for using etching primer over the fillers I wouldn't recomend it, use the etching primer first then use the filler then a regular epoxy primer.
HK [ February 28, 2003: Message edited by: Halloweenking ]</p> |
