Help indentifying/fixing electric wiper switch in '52 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2011, 12:54 PM
Hi all:
I have electric wipers in my pickup and have always had problems with the switch--it spins endlessly in both directions and you have to position it very precisely to get the wipers to run. About a month ago, the wipers stopped working altogether.
I checked, and there's power to three of the wires (the other one appears to be a ground.) I also tried jumping from the powered wires to the ground in an attempt to get the wipers to activate, with no success. I'm no electrical wizard, though, and I know that it's probably not that simple.
So my questions:
1: Is there any way I can figure out if the switch is my problem by maybe bypassing it and getting the wipers to turn on? I assume it's the switch, but am not certain.
2: Can anyone tell me how to find a replacement switch? The only writing I can find on it appears to say CULS USA BOSTON and there is also the letter F. Sorry about the quality of the photos--not much light in my garage this time of year...
Thanks for the input...
Kyle
ID:	53311   Click image for larger version
Old 03-06-2011, 04:01 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
That year originally had vacuum wipers. So this must be a conversion.
One source for parts is www.forwhatyouneed.com and maybe the wiring diagram so you can test to determine what to purchase.
vicrod
Old 03-06-2011, 07:00 PM
Hoptup32's Avatar
It looks like you have a universal wiper switch. The four posts should be labeled B(battery)(red wire) L(low speed)(white?) H(hi speed)(yellow?) and P(park)(blue wire)
Universal Switch
You may be able to find a similar universal wiper switch at your local auto parts store.
If you have power to the battery wire when the ignition switch is on, jump the battery wire to either the L or H wires and if the wipers work then the switch is bad. If the wipers do not work when you jump the L or H wires, then I would suspect that the wiper motor may have a problem.
Old 03-06-2011, 08:13 PM
Thanks for the input. I jumped it like you said and got nothing.
I figured it wouldn't be that easy. Looks like I'm gonna have to pull out the gauges and have a look at the motor
km
wiper switch Big Dog Daddy 2008 Electrical 2 06-29-2008 07:02 AM
electric wiper conversion squidward Electrical 19 06-23-2006 12:16 AM
55,56,57 chevy electric wiper moter roby,s57 Introduce Yourself 2 02-20-2006 06:21 PM
'55 Chevy OEM electric wiper motor PrimeMover Electrical 11 01-28-2003 01:22 AM
electric wiper motor eltigre Electrical 3 02-15-2002 06:39 AM
