Help installing hei distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2004, 08:57 PM
Hey, i am new to this board and need some help. I am installing a new hei distributor on the 388sbc im building. I was wondering which plug wires go to which plugs, and any other info i might need installing it, i heard the rotor has to be pointing in a certain direction, and any info i might need to know. thanks.
Old 01-28-2004, 10:42 PM
Checy_Guy's Avatar
the rotor has to be pointing to number 1 cylinder. fireing order is 18436572.
Chevy-Rules
Old 01-29-2004, 11:13 PM
the rotor has to be pointing towards number one cylinder when it's at TDC compression stroke. You find that by taking out the plug and having someone bump the motor lightly--with the ignition disconnected--and feel for the biggest "puff". This is basically telling the distributor that you want it to fire when the cylinder is at TDC compression stroke.
Actually, it doesn't really matter which way it's pointed as long as you have the right firing order and the terminal that the rotor faces goes to whatever cylinder you happen to have set on TDC compression stroke. THe only reason they say to point it that way is for ease of setting advance and making the wires look pretty.
From there, Chevy Guy's firing order is where it's at. If you forget though, its usually in a stock 350's intake casting on top of one of the runners. Oh, and with those high output coils, you definitely don't want the wires laying all around the engine comaprtment. Keep them off of conducting metal and away from the headers. Good luck.
Old 01-30-2004, 12:05 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
You don't point it at the # 1 cylinder. You point it at the # 1 cylinder wire terminal and it can be where ever you want it as long as it is in time. The book says it should be pointed at the # 4 or 6 cylinder. The wires go in the cap as per firing order going clockwise. The vacuum advance should be on the passenger side, pointing forward. HTH.
Good Luck
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
