-   -   Help installing residual valves (http://www.hotrodders.com/forum/help-installing-residual-valves-80460.html)
upthcreek 02-01-2006 07:10 AM
when installing resid. valves that have a directional arrow is it correct to have it pointing toward the wheel cyl or the master cyl? have it pointing toward the wheels but not acting right
Moon 02-01-2006 08:26 AM
Hi. Arrow points toward wheel cyl. As far as brake problems go there is a ton of info in the knowledge base.
Moon
upthcreek 02-01-2006 11:26 AM
Thanks, thought I was right but wanted to be sure before I started back at square one- Thanks again
302 Z28 02-01-2006 11:41 AM
What about it is not acting right?
Vince
upthcreek 02-01-2006 04:03 PM
feels like it may still have some air in the lines- 1st pump of petal is soft ,second is ok-wait a few minutes and try again and same result- it's a double chamber master w/ 7" booster- sound like air to you??
